Question about Garden
How to fit belt on flymo tc380 - Garden
Posted by sean mulcahy on
Andrew White
  • 2,239 Answers
Too replace the belt you need to remove the motor and base plate assembly, remove the box, remove the front cover over the motor, pull the two wires off the motor terminals, turn the mower upside down,remove the blade bolt and blade, remove the impellor, remove the four cross head screws underneath, there are two more screws toward the front of the machine, once all out the motor and base plate will come out as an assenbly, slacken the four motor screws and push the motor forward, remove the old belt and fit the new one, wedge a screw driver between the motor housing and base plate force the motot forward to tention the belt at the same time re tighten the motor screws, re assemble in the reverse order.
Posted on Jun 17, 2012
How do i fit a drive belt to a flymo hover mower
https://youtu.be/4V-ODtDzIcw this should help out its a fly mo video on changing the drive belt on your mower
Aug 05, 2016 | Garden
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Flymo instruction manuals
www.flymo.com/uk/robotic-lawnmower-support
www.flymo.com/uk/contact-us
Jul 14, 2014 | Garden
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Flymo problems model 350 clutch brake does not release causing belt to break.
The clutch brake is a non servicable item, you need to remove the motor, belt and brake assembly take out the screws, remove and replace the clutch brake.
Jan 14, 2014 | DR Power Equipment 8.00 PREMIER Electric...
Wheels will not turn on my flymo h40
if belt drive check for grass build up oil on belts worn belts or pulleys broken belt broken gear in wheel
Sep 09, 2013 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
The belt keeps coming off my flymo. but it don't look stretched. any other explanation for why this keeps happening
check the housing guard for the belt grass might be getting in and pinching between the belt and the pullies causing the belt to come off. You can use foil tape to patch any holes where grass mey be entering, duct tape might melt from the heat of the motor but you could use that as well.
Jun 30, 2011 | Electric Garden
Flymo compact350 electric grass cutter motoris
Check for debris caught under the deck. The motor may be getting ready to quit. The machine may need a replacement belt. Be careful and unplug the machine before checking.
If this is helpful, Please leave Feedback.
Thanks, SnugglePants
Oct 27, 2009 | Garden
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
