The bunn coffee pot just pours out water when we turn the switch on. The digital display reads AN000000 Asset Number. The buttons on the front are non-responsive
SOURCE: temp.
Occasionally with a Bunn you have to add some extra water. Remember when you first got it and you had to add water so that the tank is always full? It may be also that you need to turn down the temp. I need your model number to look for your manual, unless you have your manual? That is where we are going to find the answer. The model number could be on the back but it may also be on the bottom. Let me know.
SOURCE: Bunn Coffee machine only makes 1/2 pot
Alfaroo is absolutly right on, The thermostat is either set to high or is malfuntioning The water in the tank is boiling and as it expands it has no place to go but right throw the sprayhead tube and into the brew basket.
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
SOURCE: Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
