Question about HP Officejet 6310 All-In-One InkJet Printer
How do I disassemble an HP Officejet 6310
A hinge on the cover to the ink cartridge area broke. So I disassembled the printer and removed the springs from both hinges so that the printer would work. Which it does. However, I ended up with a cover harness-scan (JB63-00161A) left over. Where does this cover go?
Posted by Gordon McFerron on
5 Related Answers
Gary Oliwa
  • 11 Answers
SOURCE: Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Posted on Jun 13, 2010
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Posted on Jan 31, 2009
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: I have an HP Officejet 6310 All-in-One printer. I
Open the HP Photosmart Software on a Windows computer
1. Do one of the following:
– On the Windows desktop, double-click the HP Solution Center icon.
– In the system tray at the far right of the Windows taskbar, double-click the
HP Digital Imaging Monitor icon.
– On the taskbar, click Start, point to Programs or All Programs, select HP,
and then click HP Solution Center.
2. If you have more than one HP device installed, select the HP All-in-One tab.
Note On a Windows computer, the features available in the HP Solution
Center vary depending on the devices you have installed. The HP Solution
Center is customized to display icons associated with the selected device. If
the selected device is not equipped with a particular feature, then the icon for
that feature does not display in the HP Solution Center.
From here, you can scan, make copies, and perform maintenance procedures such as checking the ink levels for the print cartridges.
Posted on Nov 16, 2009
Testimonial: "I'm sorry. I forgot to say that I have a Dell computer, not an HP, just an HP printer. Very stupid on my part not to include such important info."
Anonymous
  • 3 Answers
SOURCE: Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
Posted on Aug 12, 2010
Walt Shuler
  • 42 Answers
SOURCE: HP officejet 6210 broken hinge on cover to access
The 6210 series are famous for broken hinges, plastic and under spring loading. One place has them but at $88 for a set it may be not worth it. See link below if interested. I have one too with same problem.
http://www.everprint.com/online/SimDetail.asp?partno=q8052-40001
Posted on Apr 06, 2011
Hello, just today my printer (HP Officejet 6310 All-In-One InkJet Printer) showed an error saying , "Cartridge Error: Cartridge in the left must be replaced. I put ink on both , just in case that was...
You need to decide upon a suitable replacement. HP recommends using their ink cartridges, but you can also choose to use a cartridge from a different brand. If you have a higher volume of prints, you may even consider refilling old cartridges to cut down on costs.
Remove the old cartridge by removing the main cover. The cartridge carriers will automatically move to the center. Press the top of the carriers to open the plastic lids covering the cartridges. Gently press down on the old cartridge and slide it out.
Install your new HP printer ink cartridge. Remove the blue protective strip from the contacts and place the cartridge in the carriers. Press down gently until the cartridge sits in its position. Replace the carrier lid and main printer cover. Restart the printer and take some test prints.
Nov 17, 2010 | HP Officejet 6310 All-In-One InkJet...
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
I just need to know how to put the ink cartriges in correctly?
Lift the cover. Lift (unlock) the lock lever, remove the cartridges. Remove the seal from the new cartridge, insert in the vacant space. Lodk the lock lever. Close the cover.
Mar 06, 2010 | HP Officejet 6310 All-In-One InkJet...
How to reset hp 6310 printer
The below are the 4 Types of Resets.
Power Drain
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Full-NVM Reset:
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
Jan 29, 2010 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 problem is insert cartridge on left
Hi, First of all remove the cartridge and clean the connectors. You might have ink on the connectors. See if it fixes your problem.
Thanks! mannu_rakesh
Aug 03, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 6310 printer ink Level doesen't indicate any ink in printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Ink level monitoring on officejet 6310
Jan 31, 2009 | HP Officejet 6310 All-In-One InkJet...
Ink Cartridge problem
The 6310 takes a #95 tri-color cartridge. #901 is for Officejet 4500 and 4600 series printers.
Dec 22, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-in-One ''Cartridge Error: Cartridge on ...''
Hi for solution do this
First put out of the printer the Ink Cartriges then
press 4 + # + OK this send you a info menu
with the nav. Keys go to CHECKSUM FOR RELOCK DATA IMPUT press Ok 5 times . Then Go out there by pressing Cancell Button ant there you go if this dosnt work at the 1rs time you need 2 o 3 times more to ensure relock data ok
bye :)
Nov 14, 2008 | HP Officejet 6310 All-In-One InkJet...
Broken hinge
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
947 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
