An f61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61 I think it's for helpful for you.
SOURCE: im having a erorr saying f61
F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
Options then are:
Good luck
SOURCE: My Panasonic SA-HT75 clicks off seconds after I
Hello.
I have a Panasonic HT-75 codes It F61 appears. What is the problem?
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
My panasonic SA VK50 sometimes don't work in aux mode. When I plug it in laptop it doesn't work. But when I touch the red pin on other side of aux with its body it starts working in aux mode. Is there any issue with current flow or any problem with its ic?
