Question about Necchi 3537 Mechanical Sewing Machine
When I press on the foot pedal the machine with sow about 2-3 sti
I have Necchi 3537 sowing machine. When I press on the foot pedal the machine will sow about 2-3 stitches then stop. Each time I press on the foot pedal I get the same response. I used it just 4 days ago and now it is having this problem. Does it just need to be oiled or could it be something else?
Posted by trudyday on
Dayton Computer
    Master:
  • 669 Answers
Usually pedals possess a variable rheostat controller that react with the action of your foot. If it fails to function normally, it suggests that a short circuit has occurred. Generally, that means an internal wire or contact opens up and stops all further activity as you mentioned. The best bet is to take the machine to your local sewing machine dealer for repairs.
Posted on Jan 13, 2018
1 Related Answer
advacak
Denny Adams
  • 125 Answers
SOURCE: Machine stops after 2-3 stitches
open your bobbin case and un jam it thread wound around the center
Posted on Dec 02, 2008
How do I wire my Piaf 130 sowing machine
it is 'sewing' unless you are going to use it to broadcast seeds, and it might be a Pfaff? :)
Ho do you mean 'wire it'? There is a wire that goes from the wall to the foot pedal, and a wire that goes from the foot pedal to the rear or the machine or to the motor itself. I have contacts for all the foot pedals.
Piaf 130 Google Search
Dec 30, 2016 | Sewing Machines
Necchi supernova julia power problem
sounds like a sew-tric plug an motor if so under the motor's electrical connection cover there is a wiring diagram moulded onto it
Feb 24, 2014 | Necchi Sewing Machines
Toyota sp100 sewing machine - can't lower foot pressure on clothing
Berend: Thick fabrics require a longer stitch length. If the longer stitch length doesn't work check your attachments for an Easy Feed foot (It sort of mimics a walking foot.)
Dec 06, 2012 | Sewing Machines
I have a Kenmore sewing machine Model:385.15212/15218 The problem is that I prepare the machine for sowing however when i press the pedal to sew it doesn't sew , what can be the problen?
Try to borrow another foot pedal, or try taking it to Sears and ask them to plug one of their foot pedals into it. It may be that is the problem not the machinie
Jul 23, 2010 | Kenmore 15212 Mechanical Sewing Machine
Using a walking foot on my Necchi 3537
Hi JoEllen,
The walking foot replaces the normal pressure foot on your machine. There is a screw on the left-hand side of the pressure shaft that holds the ankle (if your Necchi uses snap-on feet) on the shaft. Loosen this screw until the pressure foot (or the pressure foot/ankle combination) comes off. Now slip the walking foot on where the other foot came off and tighten that screw. You're ready to go!
Robbie
Jun 05, 2010 | Necchi 3537 Mechanical Sewing Machine
I have a necchi model number 537fa. the light comes on but the pedal and motor isnt running. you can manuely move the needle up and down, but the machine isnt running. could it be a belt?
If it is a belt problem, you should be able to hear the motor running. If you cant hear the motor running then it has to be the foot control or cord or possibly the motor.
Apr 20, 2010 | Necchi 3537 Mechanical Sewing Machine
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
Nov 17, 2008 | Necchi 3537 Mechanical Sewing Machine
Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
Oct 31, 2007 | Necchi 3537 Mechanical Sewing Machine
Necchi 3537 Mechanical Sewing Machine Logo
82 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
