Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
SOURCE: how do i restore to factory settings?
I have researched Toshiba website. They do not list replacement system DVD/CD there. Did find a listing on Ebay but the item was sold. Checked the manual and there is no information on restoration within it. The result is that I do not see any easy answer for you. You could contact tech support @ Toshiba, generally pay for the call and requrest from them the restoration software. Or you could buy XP CD install the CD and acquire from online the drivers for the computer. Regret that the choices are not better.
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
SOURCE: how do I reset a Toshiba Satellite Laptop to its
you use the backup disk or purchase a windows installation disk please rate if i helped
