Phone charges in bases. Flashing lights when first pluged into base, turns on but no dial tone. All other handsets work fine
SOURCE: ID Conflict with Base 1 error
hold the volume and intercom buttons together the in use light will come on and then go to menu on handset press 6 then 1 to regester that should work i just talked to a friend with a telecom buisness and he told me what to do with mine good luck
SOURCE: Can not get the second handset to register to the base
After you got the no connection message after trying to register the second handset...did you try to register it again?
SOURCE: register handset to base unit
press menu 6 on handset then press base station reg key for 2 sec till L1 L2 L3 L4 LIGHTS FLASH
handset should now show registration no between 10 and 99
