Question about Texas Instruments TI-84 Plus Calculator
Where is the apps button on the ti 84? - Texas Instruments TI-84 Plus Calculator
Posted by Walter Latapie on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Three buttons above the "7" button, marked "APPS".
Posted on Jun 15, 2012
5 Related Answers
Anonymous
SOURCE: Xmit error
You must hit the "receive" button on the receiving calculator BEFORE you hit the "send" button on the sending calculator.
Posted on Oct 23, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: Can't find the % button on TI-84 plus :(
Just hit the 2ND key and the 0 (catalog key)scroll down to percentage or just divide the answer by 100.
Please rate this a fixya
Posted on Feb 13, 2009
Anonymous
  • 69 Answers
SOURCE: How do I convert a TI-84 Plus to binary?
I am not sure, I think that you may, but you can do it the "hard way" by converting the numbers using the following list:
1--1
2--10
3--11
4--100
5--101
6--110
7--111
8--1000
etc.
Posted on May 13, 2009
k24674
  • 8091 Answers
SOURCE: Restore apps to TI-84 Plus
I am always happy to polish the apple...before I eat it. (Just joking!)
All the applications that were preloaded on your calculators are available to download freely from http://education.ti.com Use the tab Download--> Apps and software. Then select software for the TI83/TI84 Family. While you are at the site download the TI Connect, if you do not have it already. The link follows.
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there. (Beware: while applications and programs are compatible with the TI83 and 84, the Operating systems are not.)
Install TI connect on your computer and run it to open the main Window.Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is ready to communicate with the computer.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable (USB or TIsilver cable), Select Port (USB1) and Click OK..
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of course be connected to computer. To install an application already downloaded to your computer, drag it to the main window of TI Connect and drop it. Keep installing, the appilcations you want.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the Apps from a working calculator. You should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator must be set to Send [2nd][Link][SEND][C:Apps]. A list of Apps appears. Scroll down the list. If you want to transmit un app you press [ENTER] when the arrow reaches its line. Once an app is selected , a small square appears on the left. After the selection, Hit transmit. I suggest you transfer Apps, one after the other. Avoid selecting them all and send them all at one go.
If you want to transfer the OS of a working calculator the sending calculator must be on [2nd][Link][SEND][SendOS]. TI83Plus OS is not compatible with TI84Plus nor TI84PLUS Silver edition OS.
In addition to the preloaded applications, you can also transfer programs the same way. For a repository of TI83PLUS/TI84PLUS and TI84+ SE, go to www.ticalc.org (or com), visit the archive section of the site.
Hope it helps.
Posted on Oct 27, 2009
k24674
  • 8091 Answers
SOURCE: Change TI 84 OS to TI 89 OS??
And why, pray tell, would you do such a thing? You will ruin your Ti84 Plus Silver Edition and will not have a working TI89. Besides, TI connect will refuse to transfer it.
If you like the capabilities of the TI89 Titanium, buy a cheap or used one on e-bay or amazon.com and spare your TI84PLus SE.
Posted on Feb 14, 2010
How do I switch the TI 84 Plus from Germany to English
Press the APPS button. Select any of the languages (if it's in German then "Deutsch" should be there). Press 2 to select English. Press any key to exit.
Oct 07, 2011 | Texas Instruments TI-84 Plus Silver...
How can i change my language on my ti-84 plus silver addition?
  1. Use the APPS button.
  2. Use the Arrow keys to scroll down the list of applications.
  3. Find the one that corresponds to the language you want (Fran
Sep 27, 2010 | Texas Instruments TI-84 Plus Silver...
When i press the apps button, all it shows is finance... how do i get the rest of my apps back??
The Finance App is part of the Operating system. You cannot get rid of it. The other Applications can be deleted from Archive Memory.
To restore them:
  1. Download them from education.ti.com
  2. Connect calculator to computer
  3. Run TI Connect.
  4. Drag and Drop an App onto the TI connect Main window
  5. The App should transfer to calculator
  6. After transferring one or two Apps, Press [2nd][MODE] to (QUIT) and let the calculator defragment the memory.
  7. Transfer one or two more Apps.
Here is the link to the latest software page for the TI83/84 Plus software.
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
APPS are missing
You can download them to a computer from http://education.ti.com and transfer them to a calculator using the USB cable, and/or you can transfer them from one calculator to another using the unit-to-unit cable.
May 20, 2010 | Texas Instruments TI-84 Plus Calculator
Someone borrowed my calculator and now it is
Press the [APPS] button. Scroll down till you reach Spanish or Espanol. Select the app and press [ENTER]. You are given the choice of setting 1.Spanish or
2. English.
Press 2 then [Enter].
Hope it helps.
Oct 16, 2009 | Texas Instruments TI-84 Plus Silver...
How do I change the language from spanish to English? My calculator is in spanish..my guide book is in french and English. How do I change the language setting? I have a TI-84 + silver Edition! Thanks!
Turn your calculator ON. Press the [APPS] button. Scroll till cursor reaches Spanish or Espanol, highlight it and press [ENTER]. The launch screen for the App gives you the choice to set
1:Espanol as the language, or
2: English.
Obviously you select 2: and press [ENTER].
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
School disabled all my apps - now what?
Use the link cable and link your calculator to a calculator where the apps haven't been disabled. From the other calculator, send a program or an app and that should enable the apps on your calculator
Jun 21, 2009 | Texas Instruments TI-84 Plus Calculator
Degrees, minutes and seconds button
Press the blue "2ND" button in the top left hand corner, then locate the "ANGLE" button, or "APPS" button and press.
It should give you a list of symbols.
The first two are: Degrees and Minutes.
As for seconds, press the green "ALPHA" button, then locate the "+" and press.
May 19, 2009 | Texas Instruments TI-84 Plus Calculator
Xmit error
Oct 05, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
835 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
