Question about Samsung Digimax L730 Digital Camera
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Posted by c.k.kalaria on
Chris Hingee
  • Samsung Master
  • 32,281 Answers
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Jun 16, 2012
1 Related Answer
t00nz
CameraR
  • 4738 Answers
SOURCE: battery charged but camera not working
The other battery is a small watch button battery, and is strictly to power the cameras clock to keep track of date and time of each photo. Its true that it's charged by the main battery, but this little button battery will not provide operation power for your camera. How old is the main battery? They normally only last for a couple years, and usually require replacement at that point even if only used a little.
Posted on May 08, 2008
Lumia 800. Why doesn't new battery charge?
Unfortunately, the replacement battery could be defective.
Jan 31, 2016 | Cell Phones
Bon-Ton Greene Gray Portable Battery Backup for I Phone 4S Won't take a full Charge? Or Charge Phone
I can't see that anyone has commented so far :-(
Sounds like a dud battery, and if new should be returned. It would help if you can borrow a voltmeter and test that both the charger and the battery show a voltage. [a local electrics shop may help there]
Feb 10, 2014 | Bon-Ton Computers & Internet
APC Back-UPS rs900 Not working
It could be DOA. The battery may have discharged completely and was left discharged for some time
Jul 24, 2013 | APC Computers & Internet
Power on after insert charging jack for a minutes plz solution my problem
charge it for a full day before trying to turn on
my nokia was left for 6 months drained... i left it to charge overnight, but to be sure try 24 hrs :-0
May 24, 2013 | Karbonn K9
It does not turn on even if it was charged for 24 hrs
When it charges, does the red light come on on the charger? Some of the CST2000 chargers make bad connections, and they don't actually charge.
Make sure the red light is coming on when you're charging the battery. If the light is coming on and you still can't use the trimmer after charging, you'll need either a new battery or a whole new battery pack (the black handle of the trimmer).
Hope that helps!
Sep 04, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Unable to charge. it still says charging
You should return the product. This is relatively common, it needs a new battery. The battery will not take a charge. Here's the thing, batteries for cordless phones are a fortune. You should either return it or if you can't probably just buy a whole knew one.
EJ
Jul 02, 2010 | AT&T E5640 Phone
Battery charged but camera not working
Jan 10, 2008 | Sony Cyber-Shot DSC-P12 Digital Camera
Samsung Digimax L730 Digital Camera Logo
288 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
