Question about Tecumseh Garden
Tecumseh 10685 has no spark
Mower suddenly will not start. No spark. Replaced spark plug and air filter. Still no spark.
Posted by Mark Larson on
  • 2 more comments
  • Mark Larson Jun 16, 2012
    Mower was working fine for 6 or 7 weeks. Suddenly, when my son was unavailable to mow, I tried to start the mower, but there was nothing to indicate that the engine would turn over when I pulled the starter rope.
    I pulled the spark plug, connected the electrical cable and grounded the spark plug thread area against the head of the engine, away from the spark plug hole. I had my son pull the bail lever and pull the starting rope, but there was no spark.
    The spark plug and the air filter were dirty. I replaced them with new plug and filter. I repeated the spark test. There was no spark.
    Thinking that maybe the grounding switch needed to be advanced just a little more, I used a tool to pull that cable as far as it would go. I did not have extra help at this point, so I had the new spark plug fully installed as if trying to start the engine. There was not indication of the engine making progress on turning over. I still think there was no spark.
    Seems to me that either there is a problem with the magneto or coil or the grounding switch. I have a multimeter, but I am not sure how to test the latter. I have a Lawn Boy 10685 with a serial number 2500xx123 (at the moment I cannot remember those two digits, but I believe the first two digits will specify the year).
    Any counsel on how to proceed?
    I checked some of the site http://www.ehow.com/how_7363405_troubles...
    and found how to test the coil. I used the ohmmeter setting of my multimeter and found 3.33 kOhms between the terminal of the coil and the spark plug connection. My understanding is that if it read Open line, zero, or infinity, that the coil was no good. So I believe the coil is good.
    A connector that slides over the terminal of the coil has a green wire coming to that connector. So that connector forms a T intersection with this green wire. In one direction the green wire goes into a cable protector that goes into a plastic cover over the rear-while drive area. On the other side of the connector, a green wire goes around the corner of the engine in the other direction and goes up under the fly wheel. I have not yet figured out how to remove the fly wheel to see if that is in order. I will look up some diagrams if I can find them.
    That green wire that goes through the rear drive plastic cover ends up at the Module Switch, number 20 in the diagram, and part 108-0967. This switch, it appears to me, senses the presence of a bar of the grass catcher when it is in place. Right? Seems easy enough to test if that is the case.
  • Bruce Bart
    Bruce Bart Dec 14, 2019
    The module is nothing more than a magnetic switch, in line with the engine ground. Pull the bail back, and open the ground, allowing spark and the engine runs. It sidetracks thru this goofy safety switch.
    That magnetic switch senses the iron rod on the bag frame, or mulch plug, and closes the circuit.
    Simply jump the 2 wires, completing the circuit. Release the bail, when done, and the engine will still loses spark/ground out. Also, the spring-loaded flywheel brake band will still grab hold and stop, the engine.
rlev_7
    New Friend:
  • 47 Answers
The cable frm handle to keep it running is probably stretched try were it connects to engine pull it back and tie it off try that if works u need to put a washer behind cable
Posted on Jun 20, 2014
2 Related Answers
road1chevy
SOURCE: Sears Craftsman mower-Tecumseh engine 3.75 HP-
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Posted on Jul 24, 2011
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: i changed oil, blade, spark
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Posted on Aug 04, 2011
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh 13hp overhead valve snowblower engine starts fine than sputters and dies, replaced the carb with new and exact same symptoms, Lots of fuel at the carb.
Make sure the fuel is good. Ethanol laced fuel starts to varnish after 20 days and is no good by 30 days, it also attracts water. Be sure you have good fresh fuel, then try a new spark plug.
Oct 19, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Mower will not start and i dont know wut to do need help the primer button is broke and i replaced the spark plug
take the carb out remove the folat bowl, float, needle and seat. Blast all the small passages out with compressed air.
Apr 24, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
MOTOR STARTS, SPUTTERS THEN DIES
Carburetor clogged up, air filter clogged, spark plug fouled; old gas.
This is the best suggestion I can come up with on the information you gave.
Sep 26, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Toro Tecumseh mower won't start or stay running
Sounds like you need to clean the carburetor. If you need tips on how to do this, just let me know.
Jim
May 20, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Stalling
I have same mower and just fixed what seems like a similar problem description. I had gone down the fuel system route and the symptoms just didn't add up. Stopped abruptly w/o sputtering once I reached warm-up temp. Replaced the solid state ignition (34443C now part number 3444D). Problem corrected and just mowed my 1/3rd acre w/ no issues.
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Apr 14, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
685 people viewed this question
Top Tecumseh Garden Experts
Randy Schumann
Randy Schumann
Bill Boyd
jeanette
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
