Remote rm-ed016 How to install a new one
Posted by Poli Schouten on
    Top Expert:
  • Televison & ... Master
  • 76,416 Answers
Find out the setup codes for your device with the remote you have. You can get it from remote's code list. Proceedings are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Posted on Jun 15, 2012
I have a remote which doesn't work anymore. (20 year old sony LBT-V502 hifi installation and it's standard RM-S530 remote.) What can I do? is it possible to buy a new one?
That is really old. Once you have tried fresh batteries there is not much more to do.
Amazingly there is one for auction on eBay. Good luck. Personally though, I would not buy it used at that price, I'd get a nice new hifi, maybe DAB radio,
http://www.ebay.co.uk/itm/Original-RM-S530-SONY-Remote-Control-Audio-system-for-HiFi-video-CD-Tuner-Tape-/200986250606?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item2ecbb6cd6e
Nov 11, 2013 | Cell Phones
Need a code for my Sony RM-Y16 Remote to split screen with my Comcast DVR
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
Oct 07, 2012 | Sony RM-Y916 Remote Control
Rm-ed016
Direct Code Entry
Code Search
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 14, 2012 | Televison & Video
Is there a code for samsung DVD VR-357
Hello
Just checkout with these setup codes. Sony RM-V210T remote has these setup codes with Samsung DVD
0014, 0212, 0229
Ok.
Oct 28, 2011 | Sony RM-V210T Remote Control
My remote control does not work suddenly
Try installing new batteries such as Duracell batteries. Make sure they are installed properly in the remote with positive to positive nodes and negative to negative node. If you own a digital camera, you can test the remote to see if it is working. Point remote at camera (powered on) and press a button on the remote. If you see a blue / purple light on the remote's led, then the remote is working. If not, then the remote is probably broken and you need to buy a new one.
Aug 09, 2010 | Sony RM-PP404 Remote Control
Rm-1 Olympus remote. I have 2 of them and can not get them to work with my Olympus E510. New Batteries, tried to set frequency. No luck. Any advise?
Starting on page 45 of the user manual explains how to use your RM-1 remote control. You have to set up the camera in remote control mode in order to fire the RM-1.
May 10, 2009 | Olympus RM-1 Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
