SOURCE: Where is the fuel filter located on a 2006 Dodge
It is located on the driver's side of the engine. You will see a yellow handle for the fuel/water separator drain valve at the bottom of the filter housing. The black plastic top unscrews and the filter can be pulled out.
SOURCE: locate the fuel filter on a 1990 Dodge Ram Van 250
Hello
The fuel filter is located on the left side of the truck on the inside of the frame and its right below where your left foot would be sitting in the truck, the fuel line unscrews from the fuel filter there is 1 1/2" bolt holding it to the frame
SOURCE: fuel filter/pump
To my knowledge, both are integrated in a single unit together with the fuel level sending unit, the float and a return motor. They are in a coffee-can sized assembly inside the fuel tank removal from the top. The big job is bringing the fuel tank down.
A temporary workaround on stuck pump is to bang on the bottom of the fuel tank with the ignition switch ON.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Where is the Fuel Filter located on 1988 Dodge Ram 50
Under hood, center, lower engine area, between fuel pump and carburetor, mounted in fuel line
SOURCE: Where is the fuel filter located on a 2004 Dodge Ram Quadcab?
usually sits on passenger side on the inside of frame follow fuel lines from motor to tank ,its usually at the half way point between motor and tank inside frame rail
