Question about Panasonic Hdc-sd90 40x High Definition Camcorder Black
This battery cannot be used
I bought a new Panasonic battery to replace the old one, but got the same message
  • 2 more comments
  • Anonymous Jun 15, 2012
    I got my camcorder very lightly splashed with surf spray (superficially on surface). I suspect a small amount of water trickled to the battery contacts. I got the "battery cannot be used" right after that. I carefully dried any drops of water I saw, but unable to get rid of the warning.
    The camera works just fine with the AC adapter. Everything works. I bought a brand new battery and ensured the contacts were clean. Put the new battery in, and still get the battery warning, and the camera shuts down.
  • Anonymous Jun 17, 2012
    Thank you for your suggestion. I did try to gently clean the contacts, but no luck. There appears to be no surface material on the contacts, and all the contacts appear bright and shiny. I'm thinking now that perhaps if the internal battery were removed, and resetting the memory perhaps that will help...but I don't want to attempt to open the camera just yet.
  • Anonymous Jun 24, 2012
    One more bit of information. I found a repair manual for the camera, and did a factory reset. That seemed to help, and for a while, the camera worked again. The problem recurred. I noticed that when I open the video display, if there is a display with the battery time remaining, it will work. If there is no battery time displayed it shuts off.
    Here's the odd thing. When I get into the servicing menu, the battery works just fine, and I can do everything I need to do without the camera shutting off. Once I return to the video mode, if there is no battery time displayed--it shuts down.
  • dionisis_pap
    dionisis_pap Nov 14, 2012
    Hi have exctactly same problem with battery , any help please?
john morgans
    Sergeant:
  • 339 Answers
Sea water will couse rust to form on the contacts get a fibre glass pen from maplins(uk) radio shack(usa) and gently clean the with it that should cure the problem
hope this helps
John
Posted on Jun 15, 2012
  • Anonymous Aug 24, 2021
    This saved my life with all my 6 battery! THANK YOU!
Bought a new battery pack (jensen brand) for panasonic 5.8GHz gigarange supreme KX-TG6500 2Line cordless phone and it wont charge.
check that you got the right make of battery for the charger
some phones use a nicad battery and others use a lit ion battery
2 different recharegable batteries -- 2 different chargers required
I have a Panasonic DMC-LZ7 camera. I have installed new batteries, however when ever I turn the camera on it beeps and displays the message "Please replace the batteries". Is it worth while sending if for...
My DMC-LZ7 started having the same "please replace batteries" error a few weeks ago (bought in 2007). It only seems to happen with my NiMH rechargables, though they test as full-strength with a cheap battery tester. Alkalines don't cause the error and I haven't tried Oxyride (ZR6) batteries yet.
The camera has two battery-type settings (Alkaline/NiMH
After charging tz3 battery and put in camera it
Are you using the batteries recommended by the manufacturer? that is a very important fact, even though you can find other batteries that have the same specs, they make the cameras to where it will work best, and sometimes only, with the batteries recommended.
2answers
Battery discharges too quickly
Time for a new battery. They don't last forever.
2answers
"turn camera off then on again" message
There could be a short in the battery contacts in your camera. You should inspect them for corrosion or oxidation.
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Panasonic Hdc-sd90 40x High Definition Camcorder Black Logo
Top Panasonic Cameras Experts
Ekse
ENFORCER
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
