Question about Saws
Stihl ts400 throttle stuck open and trigger stiff
Posted by Anthony on
Nookster
    New Friend:
Hi Mate, Got the same problem, Have found the service manuals for the TS400, and looking at it I think it's a problem with the throttle rob connecting to the carb.
Did you manage to fix it ?
CheersSteve
Posted on Jul 22, 2012
3 Related Answers
Anonymous
  • 26 Answers
SOURCE: stihl ts400 will not stop, it carries on running
Stihl guards their service manuals making them only available to dealers who service Stihl.the kill switch is not making contact. a t25 torx should get you to the point where you can determine if my theory is correct.
Posted on Feb 27, 2010
Anonymous
  • 623 Answers
SOURCE: I bought a rebuild kit for a Stihl TS400 and the
I believe the arrow must be installed facing the exhaust.
Posted on Jun 07, 2010
Kiltnar
  • 111 Answers
SOURCE: need to know belt size fo the stihl ts400 concrete
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Posted on Mar 30, 2011
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
Stihl quick cut no start
the metering lever is stuck having been stored prior to installation
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I have a stihi ts400 disc cutter which will not switch off on the off position when the button is push forward , any solutions welcomed !!
Strip off the case check the contacts from the switch follow the wire back to the coil check to see it's connected. Usually it's the contacts
Oct 14, 2013 | Stihl Chainsaw Throttle Trigger 012 O12...
Ts400 doesn't start up, used to start but when it warm up turn off. now it'll nat start at all.
Sounds like it is Over heating to fast take to the shop and see if they can find you a part or you can try changing the fuel in it and set it in full throttle for about 5 seconds and do this for a minute.
Sep 02, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
First my Stihl Quikcut was getting too much gas now after rebuilding the carb it's not getting enough
Not sure who told you about the compression but that is not true, are you sure the throttle rod is actually pushing the throttle shaft open?
Mar 17, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Need to know belt size fo the stihl ts400 concrete cutoff saw
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
