Question about LG Flatron F700P 17" CRT Monitor
How can i reset LG FLATRON ezT713SH CRT monitor's all front panel values to factory values(in normal mode) ARUN
Brightnesss...................?(normal mode) contrast...................?(normal mode) temp...................?(normal mode) ... ect
Posted by arunpanchami on
5 Related Answers
Anonymous
SOURCE: monitor LG FLATRON E700SH
do any one have the moniter sittungs of LG E700SH
Posted on Jan 28, 2009
Anonymous
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
Anonymous
  • 460 Answers
SOURCE: i want to know ls flatron monitor shape settings
there is usually a default setting in the os menu.
Posted on Nov 12, 2009
Anonymous
SOURCE: LG flatron L1970 h monitor flickers.
Just fixed mine :)
Biggest mistake was to try to open the monitor itself :( But I didn't brake anything :D
You just have to gently open the transformer unit (power brick) and replace two identical 1000uF 16V capacitors.
Here's how:
Remove the power cord first, to discharge the capacitors to avoid any nasty shocks when inside. Remove two rubber feet on the bottom side of the power brick. Just use your nail and lift them. Put them safely for later assembling. Unscrew two screws you just found under the removed feet. Now you have to unlock the other side held together by plastic locks. Try to apply pushing force and toque with screwdriver just where the seam is meeting the power cord socket's edge. Look for two identical capacitors and check if the tops are bulged of broken. I assume they are but you can try this method anyway. When the unit is disassembled you'll have to unsolder at least one of the wires that hold shielding plate on the bottom of the circuit board. Then unsolder the two capacitors (1000uF 16V). Replace them with the same type (1000uF) and the closest voltage possible. I have replaced mine with 1000uF 24V ones and so far I'm typing :D
That's it. If you have done this and looked for other damaged capacitors and replaced them also... Well then good luck disassembling the monitor unit and checking on inverter and lamps ;)
Cheers!
Posted on May 13, 2010
Anonymous
SOURCE: LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link http://loversdelight-ididitmyself.blogspot.com.
Posted on Jun 22, 2010
What must the settings be for the colour , contrast ect ect on a hisense tv?
These controls are adjusted to give you a pleasant looking picture that suits your personal tastes. There is no right or wrong with these settings.
Sep 20, 2014 | Hisense LHD3204US 32 in. LCD HDTV
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
What's the best picture mode for my Samsung HDTV
Really that is based on personal preference. You can set your own picture by adjusting the picture settings (i.e. brightness, contrast, ect..) as well.
Nov 04, 2013 | Televison & Video
When I set my PT-D5500UL contrast mode to HIGH the picture have less light than when contrast mode set to NORMAL, is this okay or....because there should be more light when is set to HIGH?
I have a PT-D3500E and it does exactly the same as your projector. When setting contrast mode to high, the picture gets darker. I think this is o.k.
Oct 18, 2012 | Panasonic PT-D5500U Multimedia Projector
Cooling fan problems
Hi Dave the ECU receives messages from sensors, one of which is a temperature sensor. When the sensor responds to a temp higher than the normal operating temp the fans are then and only then supposed to operate. They will switch in for a brief period and then turn off again. The idle speed is in direct relation to the cold start up idle requirements and specifications. When the engine is cold the idle speed will automatically increase and as the engine achieves operating temp, the idle speed will decrease inthe way you have recorded. If you start the engine and allow it to idle until normal temp is achieved the fan should cut in. The way you've desribed all systems are A okay!. Regards John
Mar 29, 2012 | Pontiac Montana Cars & Trucks
Lincon LS 2006 5600 kl coolent fan runs in winter when the temp gage is normal the radeator is not hot.The fan is very noisy, the engin has ben bled of air. The car has ben looked at by Lincon dealer said...
the fan has a low and high speed or some have 2 fans. It comes on low speed when the temp starts to climb or when you turn the a/c, defrost, or mix mode (it turns on when the a/c compressor kicks on. If the temp of coolant gets to about 230 F, then the high speed kicks in.
What is your doing? Very nosiy sounds like high speed. Could be a defective ECT - engine coolant temp sensor.
Dec 07, 2010 | 2006 Lincoln LS
I have a LG FLATRON model L1720B, problem is that the brightnesss,contrast and gamma options in the picture can't be selected and in the auto modes all the setting is higher than usual which i am not able...
Hi. There should be an option on the menu of that LCD to return or to reset it to factory default, try doing that one it might solve the issue. Hope this helps
Jun 04, 2010 | Computers & Internet
Pictures are dark
Most picture frames have a brightnesss and contrast control. petrhaps in dusting it has been caught and turned down. If its battery change batteries.
Please rate my help++++Thanks for using FIXYA
May 14, 2010 | SmartParts INC. digital frame. 7.0 in....
Van skips and runs ruff but only after it warms up i was told could be coil ,or cam sensor or crank sensor but would look to me to do this when cold . van runs perfect when cold only starts having problem...
It sounds like like the ect sensor(eng.coolent temp)
not sending a signal to to the pcm that the engine is
warm. And the engine will stay in cold start mode.
Check the connections at the ect sensor, it's on top
of the engine on the intake manifold. Also have an obdII scan done to see if that sensor or any others
shows a code. You can stop by any autozone/napa
or advance auto parts they will scan it for free.
Hope this helps.
Feb 05, 2010 | 2000 Dodge Caravan
Best settings possible for its color contrast brightnesss etc.....Im aware of roomlighting. my caliberations are numbered not percent. help
Find what the low and high numbers are and set them to the middle, e.g. 0-10 set on 5 This is the optimized condition from the engineers. Then you can increase or decrease each parameter to your likings.
Jul 05, 2009 | Hitachi Televison & Video
LG Flatron F700P 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
