Question about Belling Ovens
Need a wiring diagram for a belling format halogen 4 electric cooker
Need a wiring diagram for oven
5 Related Answers
jackdaniels1
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
Anonymous
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
Anonymous
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Posted on May 01, 2009
Anonymous
SOURCE: WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Posted on Oct 30, 2009
Anonymous
SOURCE: how do you reset the clock when you switch on a
belling single oven. how do you reset the clock
Posted on Mar 19, 2010
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Nov 28, 2008 | Ovens
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
402 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
