Question about Vulcan Heating & Cooling
Vulcan Ilec Silhouette manual wall furnace installation guide
Posted by Fair Work on
5 Related Answers
blender719
  • 53 Answers
SOURCE: Vulcan Ilec central heater main burners turn off after few second
Flame rollout sensors, overheat thermistor, air proving switch, bad earthing, blocked flue. Any of these things can cause your problem. If its a permanent pilot, is it clean burning?? If electronic ignition, is the flame rod clean i.e. no carbon or rust etc.. Safest bet is a qualified gasfitter take a look at it.
Posted on Jul 19, 2009
Anonymous
  • 29 Answers
SOURCE: i have a vulcan silhouette manual wall furnace
YOU MUST HAVE THIS THING CHECKED OUT BY AN EXPERT. IT IS A FIRE HAZARD. Even if the thermostat was a closed circuit, the furnace would be working all of the time but it would not be overheating to the point of warping parts. You are either overfiring or your blower is not running all of the time. If it's a blower problem, clean out the dirt and dust and oil the motor. If the motor is not running, replace the fan control or the motor. If the furnace is overheating, your gas regulator might be bad allowing to much gas pressure to the furnace. Also, make sure that the burner orifice's are the correct size for the heater.
Posted on Jul 08, 2010
Anonymous
  • 304 Answers
SOURCE: Manual required
http://www.ceramco.com/pdf/neytech/neytech_dfus_VulcanBoxFurnacewithProgrammableControls.pdf
This is a link to a vulcan wall furnace manual. I'm not sure from your listing if this is the right one but it may help if programming is similar on these units. If not get back to me by posting more details for me here and I will find the right manual for you. Please do not vote on this until I find you the information you need so you can rate it fixya. Thanks,
George
If this is what you need let me know when you find out.
Posted on Jul 28, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: Hi there, I have a Vulcan Gas Wall Furnace Heater
Hi
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Thanks
Rylee
Posted on Mar 29, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
Posted on Jun 01, 2009
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
I have a vulcan silhouette manual wall furnace that gets really hot and the grill and vents are starting to warp the thermostat doesnt seem to be working, should i still be using the heater...
Jul 08, 2010 | Heating & Cooling
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Jul 02, 2009 | Heating & Cooling
Hi there, I have a Vulcan Gas Wall Furnace Heater 26.4. Would you please tell me where I can get manual book or how to use it. Thanks! Paul
Hi
Thanks
Rylee
Mar 29, 2009 | Vulcan Heating & Cooling
Vulcan gas wall furnace keeps turning off, and has err f1 on the control panel. Any suggestions? It is Sunday afternoon and about 8 degrees!
No idea what the problem is but - We have a manual vulcan gas wall furnace about 3yrs old and it has always been switching off since installed which is a real bummer on cold days. We had it checked out whilst under warranty but the technician did not fix the problem. Im not sure if it has anything to do with the gas supply but seems more of a product fault. Lucky weve got a combustion stove as well!
Jul 27, 2008 | Heating & Cooling
Manual required
George
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
201 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
