My camera lens continuously zooms automatically. The LCD and EVF is not working either. I can't turn it off or on.
SOURCE: Help! Won't turn on
Fuji suggests; "If the digital camera will not turn on, run through the "Checklist" given below. If this does not solve the problem, take the camera, the batteries, and the AC Power Adapter to an authorized FUJIFILM service center for testing and repairs. [Checklist] 1. The direction of your battery might be wrong. Confirm it and put it again. 2. Load new or fully charged batteries. 3. The battery terminals may be dirty in a way that cannot be seen (fingerprints, etc.). Wipe the terminals clean with a soft cloth. 4. Press the Power button again firmly." Cleaning the battery contacts sounds worth a try. Fuji also say; "Please use only alkaline batteries or Ni-MH rechargeable batteries with Fujifilm digital cameras Please note that instruction manuals provided with Fujifilm digital cameras recommend that only alkaline batteries or Ni-MH rechargeable batteries are used with those digital cameras which require AA or AAA type batteries. If other types of batteries are used together with an AC adaptor, this may result in the rare occurrence of the battery overheating. Please do not use batteries other than those recommended in our instruction manuals." Check that the type of battery is correct Did you buy the camera new? is it still under warranty? Here is the link to the support page for the s7000 including manuals, repair centre details etc; http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportBrowse.jsp?prodcat=616757&sscucatid=664272&sscucatid=664271 or direct to the manual; http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf Apart from contacting Fuji for service, the only suggestion I could find in the manual was that the battery cover may not be closing fully. Worth checking. Hope this helps :)
SOURCE: Won't stay turned on
Since mine was only a day or two old, I took it back to the store and got it replaced. Since then, it's been fine. Hope you have the same option.
SOURCE: camera finepix s2000 hd
Ya, the transfer wizard in Windows only gets the pics. For the vids you have to go into MyComputer, and your cam will show as removable media. From this folder, you can copy the vids: they will show no File Type, but the pics do.
If this doesn't work for you, try the Fuji update for Windows and try again:
http://fujifilmusa.com/support/ServiceSupportSoftwareContent.do?dbid=862802&prodcat=878844&sscucatid=664260
SOURCE: CAn veiw old picture but the evf/lcd screen is black?
Your shutter is probably stuck closed over the lens inside. Have a look in to your cameras lens and see if you can see the inner lens or just the shutter closed over it.
Will require servicing
SOURCE: snowy lcd screen and the eye view is also snowy
Test the camera by taking a picture and saving to the memory card. Then download it from the card to the computer and view it. If it is clear, the problem is in the playback system or the LCD.
