Sylvania SDVD8732 Player Logo
Posted on Jun 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The laser light is not lit
The disk wont spin and the laser light is not lit, i cleaned the light but that didnt change anything. I just bought it a year ago and it quit working. the company will not help me because my warranty ended last week. i really dont want to have to buy a new one.
Anonymous
Level 3:
Master:
  • Master 879 Answers
  • Posted on Jun 14, 2012
Anonymous
Master
Level 3:
Master:
Answers
879
Questions
0
Helped
143234
Points
2676
Replace the strip wire that connects laser pickup unit to main baord at first. If do not help, repalce the laser pickup unit.
Cyberhome dvd player
ok if you already have it fixed great but if not here is a solution if the other ones that were told didnt work... My sister had the same dvd player it wouldnt load any of the dvds. so she gave it to me. If you dont want to risk what im going to tell you than well u can pay 200 dollars or somthing to get it fixed. Take the top part of the dvd player off. you then take the little disk cover that holds the disk on the player off. if you can push the laser as close as you can to the thing that spins the disk. now if that doesnt work clean the lens by taking prokide or rubbing alchol with a q tip and just rub the lens lightly. it should clean that off. put everything back together and then try it. if it still doesnt work the mother board in it could be fried. if that is the case than well u can get it fixed for no telling how much. if you dont wont to pay anything than throw it away. Hope this helps!
Malfunctioning DVD player
that is normal for laser to do that.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
9helpful
3answers
Aiwa 3 disk CX-NMT 70 MODEL SPINS A FEW TIMES ON EACH DISC..wont play at all..What can I do? Thanks!!
This can be fixed by adjusting the POT on the rear side of the laser. My Aiwa had the same issue and there is an orange screw on the rear of the laser. Turn it about 1/16 - 1/8 turn COUNTER clockwise.
Please understand, this is a temporary fix, and will eventually ruin your laser mechanism completely. The company is out of business and the unit is 10 years old, so I didn't much care...perhaps I will run across a CD assembly I can replace it with, but this is a temporary fix for this issue.
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Dvd player not working
If the disc isn't spinning, and you have cleaned the lens (using a proper method) then it is likely that the laser has failed. The disc usually won't spin until the laser has sent/recieved a pulse from the surface of the disc. A new laser is usually about the cost of a new player.
2answers
Slim ps2 wont even spin disks
Does it power at all? Lights come on or not?
3helpful
6answers
Ps2 game disk wont spin
you should buy one of those laser disks to clean the laser and inside of the ps2 so it will work again cause mine had same problem and i used that and after it worked
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
