Question about Pool & Spa
Dreammaker x-400 clicking sound and pump surge
I have an older model Dreammaker x-400 spa. Everything works great until the controller shuts off the pump, either because it has reached the set temp or the timer is up. The pump stops pumping water like it should for a few seconds, then there is a repeated clicking sound and the pump surges on and off with the click. The only way to stop it is to cut the power to the spa. I have a reasonable amount of basic electrical knowledge and was hoping you may be able to lead me in the right direction as to where to start looking for the problem as this will be my first time working on a spa. Thank you for any help you can give.
Posted by Jeff Nosker on
Ian Kime
    Habit-Forming:
  • 77 Answers
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Posted on Apr 28, 2017
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Posted on Feb 11, 2007
Anonymous
SOURCE: TV won't come on, power clicks on then off
Thanks for the insight!
Posted on Nov 16, 2007
the dr
joey shearer
  • 447 Answers
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Posted on Aug 30, 2008
Anonymous
SOURCE: My self priming pool pump
You too can find out my solution for just $ 9.95. I was looking for some advice so I looked elsewhere until I found it. Thank you anyway for your time.
Posted on Jan 15, 2009
My dreammaker spa has power and lights but the pump won,t turn on.it makes a sound for a few seconds like it is trying to turn over then it stops.it was recently running .
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
The pump on my EZspa will not turn on.
Turned out to be a fuse, contacted the local dealer directly and they said dreammaker has changed vendors on the control box unit and
they have been having problems with the 250V 15Amp fuse.
Suggested that I go to a 20Amp, but that I should contact dreammaker
directly
Jan 02, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
546 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
