Question about gmail.com
Login i dont know how to get to start to even put in the user name
Posted by lisa davis on
Robet
  • 29 Answers
Report and get help online here Gmail Is Up or Down
Posted on Oct 20, 2016
Threetech Solutions
  • 634 Answers
Sign up to get access to your account.
Posted on Jun 14, 2012
Locked out of macbook air 2010 forgot username
Boot holding down the Option Key, Select Recovery Mode, when you select languish, click Windows on the top menu bar and select Terminal. Once Terminal opens, type resetpassword. You will then see a pop up window. Select Hard Drive, select USER that pops up in login screen, change the password, click save, then restart. Once your in the login screen, type the new password and your in. For all other locks (EFI / iCloud) go to www.iunlockefi.com
Jan 03, 2015 | Apple MacBook Mac Notebook
Tip
How to Set Up Windows 7 Auto Login?
Windows 7 requires that you log on with your user account information each time you start your computer. If you wish to bypass this step, learn how to <a href="http://www.windowspasswordsrecovery.com/automatically-log-on-windows-7.htm">set up Windows 7 auto login</a>.<br /> I think maybe some people will impatient of logging in every single time when reboot their computers, expecially while they are just running home computers for gaming, listening to music, seeing a film or doing something unimportant. Today we will take a look at how to log on automatically in Windows 7.<br /> Another reason is that many people always <a href="http://www.windowspasswordsrecovery.com/forgot-windows-7-password.htm"><b>forget their Windows 7 User Password</b></a>. They need comuter automatically auto login while forgot password.<br /> Overview Whether your main computer is one that you use in the Office or one of your family shares in the cave, could the life you a little easier, if not to every time it booted log. You could press the power button, then go out and fill your cup coffee or dinner start and then come back to your beautiful thermal desktop. Instead you must either wait to boot type in your username and password one or you need to do this one again on your desktop.<br /> Fortunately, there is a way to <b>set up Windows 7 auto login</b>. That being said, consider whether it safe enough to do this. If even the slightest possibility that someone should could not have access to information on your computer it press the power button and wait your PC with fire, without you know then you will probably want to keep the user name and password in position. Are concerned not at all, read how to <b>enable Windows 7 auto login</b>.<br /> Manage User Accounts Before getting started with Windows 7 auto login, you may wish to find out how to create user accounts and change passwords as needed. To add a user account, change a password or enable Windows 7 auto login, you must be logged on as an administrator.<br /><img src="make-changes-to-windows-7-user-account.jpg" /> To create or manage user accounts, click Start and type user into the Instant Search box at the bottom of the Start menu. Select User Accounts from the results. Select the account you want to change and click the option for the changes you want to make. To create a new account, click Manage Another Account and then select Create New Account.<br /> Enable Windows 7 Auto Login Once you are logged in to the computer as an administrator, you can proceed with <b>Windows 7 auto login setup</b>. In order to set up Windows 7 auto login, the first thing you need to do is to get to the Advanced User Accounts Control Panel.<br /> <b>Step 1:</b> Open the Run dialog by clicking Start, typing run and pressing Enter. You can also use the keyboard shortcut Windows Key+R. Just type in "<b>netplwiz.exe</b>" into the start menu search box, click OK or press Enter., and you&iexcl;&macr;ll see this screen.<br /><img src="netplwiz.jpg" /><br /><b>Note:</b> If it doesn&iexcl;&macr;t work, you can type in "<b>control userpasswords2</b>" instead.<br /> <b>Step 2:</b> Uncheck the box which says "<b>Users must enter a user name and password to use this computer</b>". Click "Apply" or "OK" to apply this change.<br /><img src="users-must-enter-a-user-name-and-password-to-user-this-computer.jpg" /> <b>Step 3:</b> A new dialog box will open, aptly named <b>Automatically Log On</b>. You will need to enter the user name and password for the user account that you want to automatically log on each time the computer is started. Type the user name into the User Name field, type the password for this account into the Password field and then enter the password once more in the Confirm Password field. Hit &iexcl;&deg;OK&iexcl;&plusmn; to finish your configuration.<br /><img src="automatically-log-on-windows-7.jpg" /> <b>Note:</b> Of course, these steps can work perfectly on XP as well.<br /> Tips: Not a Windows 7 user? Still Using XP or Vista? Don't know how to automatically log on other Windows Versions without entering user name and password? See these articles below.<br /> <b>How to Autormatically log on Windows XP?</b><br /> <b>How to Autormatically log on Vista?</b><br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Windows 7 Password Reset Disk [Safe Download]</a><br />
on Mar 04, 2011 | Computers & Internet
When i log in .i find myself tied into someone else. what info do you need from me to help me get off to a better start?
Are you logging in on a secondary login? This might be why....I don't know what operating system you have but you should go to control panel and the go to users. You must create your own user name to login to, or if you have been using this other persons for a while and downloaded anything to their user name...I would see if you can edit the user name you have been using and type in your name then"..once you create a new user name you are going to have to create everything you have been using on the other persons login and copy to the new login.
Jul 27, 2014 | Acer AL1914 19" LCD Monitor
Dont know my user name for my work
Adding your domain name + backslash will get you on that particular domain, whether it be your local domain or your work domain. As for not knowing your ID, ask your IT department.
Nov 24, 2013 | Computers & Internet
Login facebook put in correct user name and password
HI
make sure youre posting the correct username and password to facebook so you can login or else use the password recovery
Oct 09, 2009 | Facebook Social Network
I cannot log in bebo
bebo will not let me login!
i get to the login page to type in my user name and my password and before you can even have a chance 2 type them in ... a box comes up saying internet explorer has 2 close send error report or dont send !! and i have sent a error report 4 times and it still wont let m login on the login page !!
please can you fix this problem ??
Jun 25, 2009 | Bandai Digital Entertainment Cowboy Bebop
I forgot my user login password
boot in safe mode by pressing f8 while starting up the pc.
  • 1. Go to your start button, select “Command Prompt” from the “Accessories” list.
  • 2. Type in “control userpasswords2” and press “Enter”. This command will launch the Windows 2000 User Accounts application.
  • 3. Go to the “Users tab” and check the box labeled “Users Must Enter a User Name and Password to Use This Computer”, then click “Ok”.
another way, is look for password resetter on the web.
Apr 01, 2009 | HP Pavilion tx2500z Notebook
User password dont remember cannot get windows or anything to come on start menu or nothing aspire 5315 2153 dont know how to restore to how i bought it
try put F8 into safty model, then login in as administrator account, see if you can login, and change the new password.
plan b, if you were window XP, they are some software can be hack the user account.
Jan 14, 2009 | Acer Aspire 5315-2153 Notebook
User password for windows xp pro
You can't change the password or even break the security
still try this
but Administrator as user name and
dont put any password
if this doesn't work then u might have to format the drive using a bootable windows cd
Jan 02, 2008 | Microsoft Windows XP Professional With...
gmail.com Logo
6,555 people viewed this question
Top gmail.com Computers & Internet Experts
Marvin
Marvin
Harrie
Are you a gmail.com Computer and Internet Expert? Answer questions, earn points and help others
