Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
Need a motor for a cbt 500bw cuisinart - Cuisinart CBT-500 SmartPower Premier Work Top Blender
Posted by arnoldo fernandez on
  • arnoldo fernandez Jul 04, 2012
    I would like to thank for the solutions made available and inform that I had the motor
    fixed locally.
Lance Hill
    Genius:
  • 1,739 Answers
Cuisinart websites for both Canada and the US have parts ordering services; however they do not list parts like blender motors.
I woud suggest you contact their Customer Service to inquire if and how a motor may be made available.
Customer Service contact information is available here:
http://www.cuisinart.com/support.html
Posted on Jul 01, 2012
1 Related Answer
Anonymous
SOURCE: replace the blade driver clutch on a Cuisinart CBT-500
I had this same problem. It was solved but let me tell you it was a nightmare and we were almost sure the blender would be destroyed at least 3 times during the ordeal.
Here's a hint: the thread is on opposite to a normal screw thread so that it gets tighter as the blender spins.
Steps:
1. Take the base off the blender and pop out the motor.
2. Turn over the motor and remove the round rubber part at the bottom. You will see a flathead screw. This is where you grip the shaft that the cursed brass coupler thread is attached to.
3. Find someone else to help and also a large strong flathead screwdriver.
4. With a friend holding a screwdriver in place at the bottom, grip the top brass thread with pliers (or better yet a pipe wrench) and twist it the opposite way you normally would.
5. Become extremely frustrated by the fact that the screw thread is made of cheap metal and strips instantly and that the brass thread is also cheaply made and rips right through your pliers / wrench.
6. Find a hack saw and a hammer.
7. Cut the brass thread off with the hack saw. Hammer the stubborn remaining pieces of it off with a screwdriver. Be prepared to cut off half of the shaft.
8. Eventually you should have hammered / sawed the brass thread off. If the shaft and motor are still intact, you can now screw the new coupler on (remember - its backwards). We had only about half of the shaft thread left and it still worked ok. Make sure to do this after you put the motor back in place with the shaft poking through the top of the case. Don't worry too much about how tight it is. As I mentioned its on backwards to tighten the coupler during normal use.
9. Replace the casing and screws, don't forget that rubber thing at the bottom.
10. Curse Cuisinart and make a drink, you deserve it.
Posted on May 13, 2008
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Power light blinks and blender won't turn on
Probably just a fuse. Also try a different outlet. Check the manual for fuse location and other possible solutions.
Download Cuisinart CBT 500 Manual at Bob Manuals
Apr 11, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
My blenders just stopped working. do you have any sugestions
Consult the manual for troubleshooting tips. Other than that you may want to get a new blender as repairing it would be more costly than the unit itself.
Jan 16, 2010 | Cuisinart CBT-500 SmartPower Premier Work...
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Parts for Cuisinart CB-600 SA Blender
You have a Sam's Club variant of the model:
The blender parts are the same for that model as for the CBT-500 - food processor parts are the same as for the BFP-703
All available from www.cuisinart.com
-Tha Mp3 Doctor
Jan 26, 2009 | Cuisinart Blenders
Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Apr 13, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Thermal cut off fuse replacement
I worked for sunbeam and they were 10amps there. dont go to high because u start a fire ..also while you replace it look for darker or blacking field wires..all wires should look good. but hard to start a fire when u got your finger close to off the button at most it will do is slow down and stop ...smoke...time for new blender then. CrazyLarry
Jun 03, 2007 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
362 people viewed this question
Top Cuisinart Blenders Experts
ThaMp3Doctor
ThaMp3Doctor
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
