My armada e500 compact have built-in processor and when i power on my laptop heatsing become on. but processor not become in work
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
SOURCE: Compaq Armada E500 - Increase Memory
Try one only 256 it should work now. You cannot use a 256 with a 64 it just will not work it is physically impossible. I know with some of those older models and Im picking yours is because you mention you were using 2x64. What you should have done was to buy two x 128 I am possitive your board can only handle 256mb of ram. Try the one only and if it works use that I dont think two of them will work not on that board?? Let me know ok. You might wanna clean your machine out with a software like this and its 30 days trial but has all features till it expires: http://www.tuneup.com. else if you dont want to take my advice on your laptop you can always go here: http://www.compaq.com
SOURCE: COMPAQ ARMADA E500 PC notebook
Please specify your motherboard details and i will tell you a work around for breaking the password
SOURCE: Compaq Armada e500 won?t recognize the cd drive
Simple things first: Assuming the CD drive is removable, remove it from the laptop then re-iinsert it making sure it's pushed home properly so that the connectors seat properly.
If, again, the drive is in a bay (i.e. it's removable) then it may be the connectors are worn/damaged. If it's the drive connector then it may be repairable or you might pick up another drive, perhaps on eBay. It may also be that the drive has simply given up the ghost - so back to eBay :) If the connectors on the laptop have got damaged then you're looking at dismantling the laptop to repair/replace them, if that's possible.
If it's an external drive then the advice is very similar - check out the connectors first. If they look OK then you probably have to suspect the drive itself.
For either type of drive, there is always the small chance that the IDE controller channel on the motherboard has died - I have seen this happen in rare cases. Your options then are a bit limited. IIRC, that PC has no USB2 and even if it did, it wouldn't boot from a USB CD. You can get a PCMCIA interface card (now called simply PC interface) for an external CD. Depending on the card-drive interface, you might be able to boot from that.
If you need to install software onto the machine & have another (desktop) PC to hand: remove the disc from the E500, get a 2 1/2 to 3 1/2" disc adapter & temporarily attach the drive to the desktop as a secondary (i.e. not boot) disc. You can then load software onto the drive although you can't do a Windows install that way. If the machine already has an old version of windows on it, you can copy for example, the XP install files onto the drive, put it back in the machine & run an upgrade. Not the most desirable result but may be OK.
SOURCE: compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
SOURCE: Hard drive & Memory
it depends on the motherboard but i would say you can probably go to 2 gb ram. now the hard drive you can use any size you like. if you want to purchase this parts check out these stores and websites.
best buy
circut city
office depo
newegg.com
