Im wanting to respray my zapp frame black as its really scratched,what type of paint do i need and whats the process ie how do i sand?primer?thanks
SOURCE: quinny zapp, how to open
I find to fold it, I place my foot on number 3 and push a little then press number 2 and 1 and the same time and fold the seat unit. Then just push down ontyo it untill t is fully folded. I find it to difficult to press 1 then 2 then 3 - 3 always gets jammed if i follow their instructions.
To unfold pull number 3 untill it clicks then nfold seat unit an click the middle handle - hey presto buggy shuld work :)
i thk the instructions tey give a more work than needed.
SOURCE: problem with zapp seat
There are two blackclips on the top inside handles pull these gently to loosen the seat cover. Then repeat on the bottom. You will also have to unbutton the back of the seat (there are two black straps) then half fold the buggy and pull the seat towards you. Its a bit niggly and frustrating but does eventually come off.
SOURCE: i purchased a quinny zapp
Removing Seat
It is necessary to remove
the seat from the frame
when preparing to use
the car seat adapters.
Unzip seat zipper at the
back of the seat.
To unclip the seat from
the frame, fold stroller enough to
relieve the tension on the clips.
To view instruction manual with pictures for further assistance. Go to the Quinny page below and download the manual.
http://www.quinny.com/quinny/productdetail.aspx?id=29
Good Luck! from Moms Just Know
SOURCE: hi, quinny zapp
Here is the US distributor of parts for all Quinny Strollers...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
SOURCE: Which car seat fits the Quinny zapp
Hi, all the maxicosi carseats will fit onto the zapp using the adaptors that come with the zapp pushchair (but not the newly rebranded bebe loola).
The difference between the maxi cosi cabriofix and the ordinary cabrio or citi is that the cabriofix can be attached to the maxicosi in-car seat base (easybase or easyfix), whereas the cabrio and citi can only be fitted in the car using the cars seatbelts, they wont attach to the incar base. Hope I have helped a bit x
