Question about HP LaserJet P2015 Printer
There is no paper Jam. on the control panel the jam light remains on. There is no connection between the printer and the computer. But the cable is ok, because it works on the same other printer.
When we try to install the driver software that comes together with the printer, to copy the driver files to the computer there is no connection between the computer hardware and the printer. There is no paper jam, but the jam light is on always. I think it is the control board problem. If it is send me the circuit board diagram so as to see the problem on the board. My email address is [email protected] We need an urgent respond from you, because 2 identical printer out of four have the same problem.
Posted by wondimu on
Vinaya Kumar Kuchipudi
  • HP Master
  • 1,121 Answers
Remove side & back covers before starts is activity:1. Check whether printer initializing after powering on? If the error appearing after initializing check is there any paper jammed under the registration assm area.
2. If the error showing straight away after power on, check paper jam in duplex unit. check paper out sensor & sensor flag located in fuser assembly . Fuser assm located at back side of the printer.
3. Remove and refix all connectors on DC controller ( you can observe the connector below user assembly..
Posted on Jun 13, 2012
5 Related Answers
Anonymous
  • 254 Answers
SOURCE: What paper jam?
Does the printer even try to pick a piece of paper from the supply tray? If not, then it would appear that a sensor somewhere in the paper path is bad, either mechanically or electronically. Often, these sensors have a lever which touches the paper. If by chance the lever is broken or stuck it won't give a correct message to the logic circuit. If by chance the sensor is electronically defective, it would still give a bad message to the logic, and it would need to be replaced. Logic circuitry could be bad, in which case, replace the printer. With the lowcost printer/all-in-one units these days, it seems fixya has a continual flow of inquiries. Maybe this will give you some help.
Posted on Aug 09, 2007
Anonymous
SOURCE: deskjet printer problem -paper jam still remains on the coputer mode.
printer is not working not printing
Posted on Dec 18, 2007
Inkworks
Orn Wilson
  • 104 Answers
SOURCE: Paper Jam
Sometimes the "paper jam" with no paper is due to the printer not being able to feed paper in to the machine. You send a print job to it...printer attempts to feed paper but can't...then you get the paper jam message and ofcourse there is no paper in the machine. Powering off and on should clear the message. Make sure you clear the print job from the print que or the same thing will happen on power off/power on because the computer will still try to send the print job to the printer when turned on. I have found that all of HP's machines that have this style of paper feed mechanism fails prematurely. The pickup roller is too small for one but as soon as the roller is coated with dust it begins to fail. You can take a Q-tip and go in from the back to try and clean the roller. Water is fine.
Inkworks
866-381-0541
Posted on Nov 06, 2008
Anonymous
  • 53 Answers
SOURCE: My HP Deskjet 3740 had a paper jam. I removed all
You have to check if there is still a piece of paper jammed in the printers rollers/gears. It is inside when u take the lid off. After that you can try to recalibrate your printer from the software which came along with the printer. Try these and give more clarification.
Posted on Mar 10, 2009
vanherringto
J. Van
  • 1738 Answers
SOURCE: HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Posted on Feb 09, 2010
How do I copy smart label printer files from desktop to laptop
I'm making the assumption that your SmartLabel printer was installed on your desktop computer and now you want to use the SmartLabel printer on your laptop. I'm also assuming your what the addresses from your desktop computer. That said...
Seiko has eliminated the software and driver support for all older models but you can download the needed software from a third party site. Here's a link to the very stable version 4.61
Seiko SLP 100 Free Driver Download
Make SURE your SmartLabel Printer is NOT Connected!
Set Up Steps
A. Install SmartLAbel Printer on your laptop
1) Copy the Seiko software onto your laptop and begin the installation program.
2) At the point were the installation program asks, connect your SmartLabel printer
3) If the SmartLabel program is open, close it
B. Retrieve your SmartLabel addresses from your desktop
1) Look for the SmartLabel directory under Program Files on your desktop computer
2) in this directory find a file named label.sll This file holds your SmartLabel 100 addresses.
3) Copy the file to a USB Stick
C. Transfer your labels to your new installation on your laptop
1) After installing your new SmartLabel printer on your laptop. Insert the USB Stick in your laptop
2) Copy the label.sll file into the new SmartLabel directory under Program Files.
3) Start the SmartLabel software and open a new label, you should see the addresses from your desktop computer
4) If you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Hope this helps
Sep 28, 2014 | Seiko Smart Label Printer 100 Thermal
Lost software to printer
You can download software from HP website, I will give you the link
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Tip
HOW TO CONNECT PRINTER TO MAC
<br />Acquire the Mac printer driver either by downloading it or getting it on CD. Most printers come with the drivers needed to run the printer. You can also check the printer manufacturer's website to get the correct drivers.<br /><br /><br />Be sure that your printer is connected to your Mac and turned on. Reboot your computer if you connected the printer after your last reboot.<br /><br />Double click on the .dmg or installer file for the driver. If you got the software on CD instead of downloading it, load the CD into your Mac and then double click on the .dmg file. This is called "unpacking" the software.<br /><br /><br />"Mount" the printer driver by copying the files to your hard drive. To do this, just drag and drop the files into the folder where you want to save your software. The Mac will then copy the files to the location you specified.<br /><br /><br />Follow any further instructions the installation software gives you to complete the installation process.<br /><br /><br />"Eject" the .dmg or installer file. To do this, drag the file from your desktop into the trash can.<br /><br /><br />Open the Print Center on your Mac and then click the "ALT" key and "Add" at the same time. You should see a list of printers that includes the one you are installing. Choose this printer and click the "Add" button in the dialog box.<br /><br /><br />Reboot your computer if you do not see the printer on the list. Be sure that the printer is turned on and connected to your Mac first.<br /><br /><br />Your printer might already be on the printer list before you install the manufacturer software. If this is the case, remove it from the printer list before you install the software. Then add the printer back to the list.<br /><br /><br /><br />
on Jan 30, 2011 | Office Equipment & Supplies
My laptop doesnt have a cd-rom, how can i install the printer?
You can try downloading just the driver of the printer and then install it on your computer.
You may also borrow an external dvd drive so you can use the cd that came with the printer.
Or if you have another computer with cd rom drive, you can insert the cd there, copy the installation files to a usb flash drive and then run the setup.exe in the computer with no cd rom drive so you can install the printer.
Mar 09, 2011 | Computers & Internet
I can no get my printer to scan to my computer
Do you have the full software (MP Navigator) installed? Get that software here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp510#DriversAndSoftware and select your OS. Since the printer is a USB printer, is it directly connected and did you install the software before connecting the USB cable? If you didn't install the software before you connected the USB cable, uninstall the generic driver from the OS and remove the USB cable. Then install the software.
If the full software was installed before connecting the printer, try a new cable and a direct connection (instead of a print server or USB hub). Scanners require bi-directional communication with the computer and can fail when the printer works. Make sure the monitoring program is running before attempting to scan from the all-in-one.
Next try to scan from the computer first. There are buttons in the MP Navigator software that set the destination and default settings of the buttons on the all-in-one. After you scan at least one item, you will have a better idea of the settings that you need to use. See the MP Navigator help files for the details.
If you install the basic Canon driver, you will be able to scan but not from the unit directly. Windows XP and newer all come with Paint that can acquire scans (File > Import from Camera or Scanner > New Scan). Windows Vista and Windows 7 have Windows Fax and Scan that can also scan files (New Scan). Photo Gallery in Windows Live (comes with Vista) also handles scanning.
The generic OS driver usually only runs the printer.
I hope this helps.
Dec 10, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Wont scan to computer
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Dec 02, 2009 | Brother MFC-465CN InkJet Printer
Canon mp240
Go to the canon site and download the xp drivers, remove the driver
and software, clean your registry, and reinstall the software and driver.
http://www.usa.canon.com/home
Pretty good registry cleaner for free,,
http://www.ccleaner.com/download
Apr 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I can't copy documents using the front panel buttons
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 12, 2009 | HP Photosmart 3310 Printer
HOW DO I CONNECT MY 5610 ALL IN ONE PTINTER TO MY COMPUTER WINDOWS XP, SO I CAN MAKE COPIES
Connect your printer to your computer either by the parallel port or USB whichever connection is available.
Then after you do that click on the link below:
HP Officejet and PSC Full Feature Software and Drivers
Click on the download button and download the file to a location that you will remember. After its done downloading then double-click on the file and let it run. It will install the drivers for your printer and install the printer software as well.
After this you may need to reboot the computer and after that you can use your all-in-one to make copies, print pages, etc.
Mar 04, 2009 | HP Officejet 5610 All-In-One InkJet...
I have lost original CD with printer software
PRINTER DRIVER DOWNLOAD.
1) Go to http://www.epson.co.uk 2) Click on PRINTERS, select INKJET, and then select your printer from the list. 3) Select on WINDOWS under DRIVERS AND DOWNLOADS. 4) Select the most current version of the driver for your operating system and click DOWNLOAD NOW. 5) Respond to the Download Survey and ACCEPT the license agreement. 6) Make a note of the file name and save the downloaded file to DESKTOP in order to easily retrieve it.
Automated USB Driver Install
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off. 2) Locate and double click on the downloaded driver installation file. 3) Click on OK at the first WinZip screen. 4) Click on UNZIP at the second WinZip screen. 5) Click on OK when WinZip is finished extracting files. 6) At the PRINTER UTILITY SETUP screen, click on OK. 7) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer. 8) The computer will install the new hardware. 9) Click on OK when the driver installation is completed.
Your printer is now ready to use.
Nov 24, 2008 | Epson Stylus C46 InkJet Printer
HP LaserJet P2015 Printer Logo
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
