Watches Logo
Posted on Jun 13, 2012
How do you change the time on vintage Syroco wall clock?
I bought an older style Syroco wall clock at a garage sale, it is battery operated and does make ticking sound. I'm not sure how to change the time without messing up or breaking the hands. Needing some help here... I think the Syroco brand was from the 50's/ 60's era.
harrelsonroy
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 09, 2012
harrelsonroy
Contributor
Level 1:
Answers
Questions
0
Helped
1159
Points
0
I bought a Syroco 8 day wall clock wind up with key at an auction it winds but does not make ticking sound and does not work ANY IDEAS?
5 Related Answers
Ray Murphy
  • 68 Answers
  • Posted on Feb 22, 2008
SOURCE: wall clock not working
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
Anonymous
  • Posted on Sep 20, 2008
SOURCE: repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
A
Anonymous
  • Posted on Feb 10, 2008
SOURCE: Second Hand
smash it with a hammer
Anonymous
  • 2501 Answers
  • Posted on Jan 05, 2010
SOURCE: I have a Karlsson wall clock sold by Dwell. The
While there may be a way to modify the clock to take a larger battery, I am sure that the manufacturer is dodging his responsibility for poor performance.
Clocks should run for about year or so on a battery. I suggest you send it back and insist on a replacement because the mechanism is obviously faulty.
Don't take any disclaimers from the supplier, it is plainly not "of merchantable quality" and should be replaced free of charge.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 15, 2010
SOURCE: how to change clock hands
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
1helpful
Infinity group Pendulum Wall Clock not longer keeps time at all
Check that the hands are tight and also that they are not touching. and jamming. Remove the battery and replace it. Some have a lever to give it a jolt to get moving.
https://www.google.com/search?q=Infinity+group+Pendulum+Wall+Clock
Mar 12, 2023 • The Watches
How do I adjust the time on a syroco starburst clock
One of two ways. Move the hands clockwise to where you want. If the hands do not move freely then there is a concealment cover on the front that will expose a key hole for you to adjust. The key used for this is usually a square shape.
Feb 17, 2015 • Watches
How do activate the chime on a Linden 31 day wall pendulum clock?
I have same exact problem, did you ever find an answer?
I picked up a Bulova "8" clock at a garage sale and the it doesn't run. Looks like an annivesary desk clock. I took the back off and I don't see any place for batteries. There is a "Time...
If it is a spring driven clock, then there should be a hole with square shaft in the middle.
On larger clocks the hole is at the front but as yours is a desk clock, the hidden inside the back sound a reasonable alternative.
If there is no key, then you should be able to get one from a clock shop.
Mar 19, 2011 • Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 • Watches
    1helpful
    Jan 05, 2010 • Watches
    97helpful
    5answers
    Hi i have an alarm clock digital it is called an ascot by kripplwatches the serial number is... po5623 type .. hsd110b it is only a cheap thing but i like it and can not fiind instruction manual can you...
    to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
    to set the date: same prcedure as time but first switch to the date display
    Jan 03, 2010 • Watches
    7helpful
    Repair of battery-operated wall clock
    Top Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Watch Expert? Answer questions, earn points and help others
