Cars & Trucks Logo
Posted on Jun 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cvt light indicating over heating. Stops car lets it cool down and then completes his trip. Dealer could identify problem or diagnose the problem.
  • marvin16 Jun 13, 2012
    Dealer indicated there was no codes and can't resolve problem!
Anonymous
Level 3:
Master:
  • Master 560 Answers
  • Posted on Jun 13, 2012
Anonymous
Master
Level 3:
Master:
Answers
560
Questions
Helped
178768
Points
1771
Can i tow a trailer with my 2005 Honda Odyssey with a cvt transmision
Better check your owners manual and ask your local Honda dealer service person, before doing so. CVT tranny has been annoying for many with them, as they seem to fail and require rebuild too often. The tranny is always shifting for best gear so it may overheat fast especially if it came with no heavy duty tranny oil cooler that is like a radiator but smaller, to cool the special CVT tranny fluid.I wouldnt try it, but check with the manufacturer dealer , Honda to confirm my guess its NO.
2answers
Why are abs, oil, brake lights coming on, speedometer stops working, ac stopped cooling?
That's still under warranty, is it not? Take it to the dealer - let the manufacturer pay for the fix.
2009 Mitsubishi lancer GTS car problem
Something on the intake side of the motor may be loose sucking air casing the engine to compensate by adding more fuel
1helpful
Cvt light on indicating over heating. Stops car lets it cool down and then completes his trip. Dealer could not identify problem or diagnose the problem.
I do not know why your local Mitsubishi dealer cannot figure this one out. What you are describing is a known problem for which Mitsubishi has published a Technical Service Bulletin (TSB).
The problem is caused by incorrect transmission fluid levels and there is an updated dipstick included in the fix.
MITSUBISHI TSB REFERENCE NUMBER: TSB-10-23-005
You may also want to talk to your son about heeding warnings from your vehicle's onboard computer system. When the CVT transmission begins to overheat, the CVT light will come on, a warning chime will sound, and the words "SLOW DOWN" will be displayed in the Muti-informational Display. This will occur LONG before the vehicle goes into "REDUCED POWER" mode. If he would slow down as he is being told to, the warnings will extinguish themselves as soon as the transmission fluid temperature drops to a safe level (which it will, if he slows down).
REDUCED POWER MODE is like an angry parent...."OK, you don't want to slow down like I told you to do, and you are going to destroy my transmission by ignoring my warnings, so I am shutting you down!!! You won't slow down, so I am slowing you down! Now, if you do not want this to continue, then you better start listening to me!"
Similar things will happen if you choose to ignore engine control or Brake/Traction Control warnings. The old days of ignoring warning lamps and running around with your dash lit up like a Christmas tree are over. There is a new sheriff in town called REDUCED POWER MODE.
My 2000 lincoln ls has a check transmission light on. the dealer told me it was only a bad sensor. But i tried taking it up mount lemon and the transmission overheated and completly stalled out. i let it...
the dealer didn't want to fix it so he fobbed you off
overheating could be low oil or over full and as it is a Ford product , probably has a sealed transmission so with the light on you take it seriously
I suggest that you take it to an accredited professional auto transmission shop and have it properly diagnosed
if it is a sensor , that will be a lot cheaper than a transmission
On my 2009 1500 silverado, the driver side air cond blows HOT air as if the heat is on, but if you cycle the driver side temp control up then back down several times or turn the truck off like short trips...
There is a damper that controls whether heat or cooling or somewhere between that is controlled by the temperature controls. A separate system is controlling the passenger side and the driver side heating and cooling. I hope this is still under warrantee. If not it might be a big job to diagnose whether the problem is in the heat and cool controller, the wiring or the damper device. I hope this helps.
I have 2007 Mercedes C230 with 71,000 miles. It has had oil changed recently. Check Engine light came on yeaterday. What are the problems associated with this indication and what can I check without a trip...
before go to the dealer you can only do one thing, stop your car at flat floor for one our, then check oil level, if oil level lower or higher than lower level and maximum level it can be create engine light on, otherwise you have to go to the dealer and fix diagnose CPU in to your car and find what's the wrong, some time it's could be cam angle sensor faulty there are 4 cam angle sensors in your car have to be diagnose to find fault. however you must have to go to dealer for erase fault, is this information helped you?
10helpful
4answers
I have a 2009 Altima car and the transmission had to be replaced. Does Nissan have a history of problems with transmissions ?
the cvt transmissions have become a known issue, and nissan (in canada, not sure about usa) has since offered an extended warranty to 200000 KM ( 120000 M ).
2helpful
2answers
CVT Transmission oil change
have 05 freestyle trouble code p2106 came up dealer said it was eletronic throttle body what is this part
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mitsubishi Expert? Answer questions, earn points and help others
