Question about Samson SX1200 Amplifier
ONE CHANNEL OF MY Samson SX1200 Amplifier IS NOT WORKING
2 Related Answers
Anonymous
  • 14 Answers
SOURCE: Samson Servo 170 Amplifier
check see if youy have some coving the vent or the speak connect right
Posted on Dec 22, 2007
Ironfist109
Iron
  • 3018 Answers
SOURCE: one side of the amp
Either the channel on your radio is not working. Or the AV cord you are using is not working on one side (reverse the cord and plug it in the opposite you are using now. If it still only works on the one side your cord is good.) Or the final transistor for the channel on that amp might have blown. You could also have a cold soldier joint on or otherwise faulty jack plug. Let me know if this helps you find the issue.
Posted on Mar 07, 2011
Samson SX1200 - Protect light on. No blown output transistors.
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Oct 11, 2014 | Samson SX1200 Amplifier
How do you connect the Samson sx1200 with other amps?
What are the other amps and what do you meed by connect. More information is needed if you want help.
Jun 16, 2014 | Samson SX1200 Amplifier
My speakers stopped working
Heating of the power transistor
can be one of the causes.
you may have to take out the complimentary pairs to check.
The pair may take out the drivers and some components along with it.
These may take some time, (troubleshooting)
But have a tech to guide you, if you need to DIY.
Good luck, let us know what you find or needs further assistance.
Oct 02, 2012 | Samson SX1200 Amplifier
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
One side of the amp works but the other side doesnt drow signal of a samson sx1200
Mar 07, 2011 | Samson SX1200 Amplifier
Hi, i have been suggested first a Samson servo 600, then a sx1200 is there a difference between the 2? is one better than the other?
the servo series is geared more towards studio applications and/or installs, while the sx series are geared for live pa applications. the servo 600 is 300 watts per channel @ 4 ohm, and the sx1200 is 450 watts per channel at 4 ohms. the sx amp can also be bridged over to mono mode, where it puts out, i think, 1100 watts mono.
the only variable i havent been able to cover is sound quality, and im not seeing those listings in the specs on the samson website
Jan 12, 2011 | Samson SX1200 Amplifier
Right channel stop working
cheak your speaker wire and speaker at right channel.
Jan 17, 2008 | Samson SX1200 Amplifier
Right channel
it is easy to change your output device(tansistor or ic)in good charge.
Sep 24, 2007 | Samson SX1200 Amplifier
Samson SX1200 Amplifier Logo
110 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
