Question about Lenovo 3000 N500 Notebook
N500 will not charge
A few days ago, I charged another computer (Packard Bell) with the Lenovo charger, and it worked out fine. Now, when I put in the charger, the battery light blinks very fast and the blue ON - light is showing even when the computer is off. When I turn on the computer, it says there is 0% battery left and turns off. What to do?
Posted by Hans Digranes on
Chris Hingee
  • Lenovo Master
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Jun 13, 2012
5 Related Answers
Anonymous
  • 39 Answers
SOURCE: Lenovo 3000 N200 battery wont charge
no it might not be a battorey problem it could be a software problem,
Posted on Sep 13, 2008
Anonymous
  • 68 Answers
SOURCE: My laptop won't turn on
Charlotte
Can you remove the battery? If so pop it out and leave it out for a couple of minutes then pop it back in and see what happens.
Regards
Nick
Posted on Oct 26, 2008
Anonymous
SOURCE: turning off the mouse pad on Lenovo 300 n500
You have a button just to do that simle task, its un the upper right side and it has a touchpad on it, press it, looks like a display but its a button :)
One image worth 1000 words:
http://www-307.ibm.com/pc/support/site.wss/71738_touchpad.gif
Complete guide found in LENOVO support:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-71738
Posted on May 24, 2009
Anonymous
SOURCE: Lenovo 3000 N200 battery not charging.
I just had the same problem. My battery had discharged to less than zero and would not start even though the power plug was in. I tried everything... but what fixed it for me was to remove the power plug, remove the battery, plug in the power cord and start the machine. Once the machine was already booted, I put the battery in and it started charging. Dont know if that will fix your problem, but it fixed mine.
Posted on Oct 22, 2009
Anonymous
  • 38 Answers
SOURCE: How to reset a lenovo n500 to factory state from
Turn off the PC. Then press the Novo key until it boots. You'll find the options there.
Posted on Oct 28, 2009
Packard bell easynote new95 will not charge up or stay turned on. I have tried a new battery and charger but still have the same problem. Can anyone help please.
If you already have replaced your battery then you might need a new charger which is not charging your any battery at all.
Oct 28, 2013 | Packard Bell Computers & Internet
Packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Apr 04, 2012 | Computers & Internet
Hi Guys I have a Packard Bell MS2273. It was
Hey,
My understanding that your PC has a battery issue.
Could be that the battery cells are dead and can no longer be charged. Consider replacing your battery with a genuine exact same type.
Using the AC adapter without the battery does not work with all Laptops, yours might be one of such. It is not really advisable.
Also ensure your charger is working properly. This should help.
Enjoy.
Aug 03, 2011 | Compaq Computers & Internet
Hi, My Packet bell laptop wont accept power from the charger while the indicator on the charger shows that it is on and power is flowing through,the bettery was cheked and it looks fine and correctly...
Most likely the battery has reached the end of its usable life.
You'll need to buy a replacement battery and properly recycle the old battery.
Had you posted the model number of your laptop, I would have provided you with some online examples of stores that sell replacement batteries.
Dec 20, 2010 | Packard Bell Computers & Internet
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Packard Bell 4451 lap top will not power up.
check the back of the power connector to see if it is loose. I have known alot of situations were, if not carefully removed, that power connector in the can free itself from the sodder on the Mother board therefore you wont be able to charge the battery nor boot up. hope that helps
Mar 18, 2008 | Intel Motherboard
Charging
If you can charge your battery in another notebook than borrow that notebooks power adapter & try it on your notebook with & without your battery in your notebook. Your power adapter may be devfective. Listed below is a link to your notebook. Included is all the updates for the,
Packard Bell Easynote R1935 Laptop
P/N : PB42B01001
http://support.packardbell.com/global/item/index.php?pn=PB42B01001&g=2000
please vote...
Feb 16, 2008 | Packard Bell (181379) Motherboard
Acer Aspire 5100-5840 USB Problems
Is your laptop still under warranty? I would go to the manufacturer first if it is.
If not:
the system clock is run by the CMOS battery. When low will cause a host of problems. Change it and let me know if this fixes your problem.
Dec 27, 2007 | Acer Aspire 5100 Notebook
Lenovo 3000 N500 Notebook Logo
213 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
