Altec Lansing ATP 3W Computer Speakers Logo
Question about Altec Lansing ATP 3W Computer Speakers
Altec Lansing ATP3 broken speaker wire ORANGE connector/jack.
I have an altec lansing atp3 Speaker and the right satellite subwoofer jack (orange connector) broke. What I did was strip the covers and tried connecting and fixing and soldering it back. The problem is, I am not familiar with the setup of the wires and screwed it up. HELP!
  • Anonymous Jun 12, 2012
    Wiring diagram for Altec Lansing tp3 for the right satellite (orange connector) jack to connect to the subwoofer.
    I stripped everything on the yellow jack.. i took the rubber head coating and everything that covered the wires cause i found out the the ring inside the yellow jack was broken and i soldered it back.. the problem now is the wiring diagram and where do i connect the rest.. can we post pictures here??
Anonymous
    New Friend:
Altec Lansing ATP3 broken speaker wire ORANGE conn - 8_27_2012_11_20_47_am.jpg
Here you go
Posted on Aug 27, 2012
  • xenomorphy35
    xenomorphy35 May 05, 2015
    there is no golden wire, must be bluegolden.
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: Altec Lansing ATP3 Speaker System Not Working
try to replace the power-amplifier TDA7377
Posted on Mar 08, 2009
Anonymous
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
Anonymous
  • 3600 Answers
SOURCE: My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
Posted on Aug 20, 2009
Anonymous
  • 363 Answers
SOURCE: sliced control cord
Not quite sure how many cores you sliced then soldered. Did you repair a figure-of-eight (two co-axial cables stuck together) or was it two inner wires with a braid over both (round)? Can you give more info or a picture? Just want to help. Regards
Posted on Sep 27, 2007
Where im going to find connectors of atp3
Altec Lansing ATP 3 has 7 pin mini-DIN connector for Right Satellite. You will find that at electronic hardware store. WebRepOverall ratingThis site has no rating(not enough votes)
1helpful
Is there a way to use the Altec Lansing VS4121 Subwoofer as a stand alone?
Normally these low end system components depend on each other and cannot be interchanged with components from other system. So if one of the components (subwoofer or right control satellite speaker) breaks or gets lost the whole system is unusable...
I was in the same situation. Got a subwoofer from VS4121 without original satellite speakers. I acquired satellite speakers from Altec Lansing 251 which used same connectors but the internal wiring was different and incompatible. Speakers are also glued together so it is impossible to open without damaging it. Obviously there is no service documentation anywhere..
But if you like electronics you can try to make something based on the information below:
Altec Lansing VS4121 connector pinout:
Take the male connector (from right satellite speaker) and number pins in first row from left to right as 1-3, pins in the second row as 4-7, pins in the bottom row as 8-9 and the circle enclosure as 0. Then:
0 - Ground
1 - Speaker Right
2 - Treble (seems just like voltage control but may need to be confirmed: Min=0V; Max=voltage from Volume control Pin 9)
3 - Head Set Right
4 - Bass signal (not sure what the exact original design is as I have not opened the speaker) But seems like they use 50K potentiometer and some sort of RC low pass filter configuration. When potentiometer is set to Min it is shorted with ground. When set to Max it is taking signal from Right and Left Head Set (pins 3 and 5) combined through some larger resistors and low pass filter.
5 - Headset Left
6 - Ground for Headset (grounds 0 and 6 seems to be connected in the subwofer but within the right satellite speaker they seem to be isolated with separate leads to sub)
7 - Power ON/OFF. When OFF or headset jack plugged then 0V. When ON and headset jack unplugged then 5V
8 - 5V Power in
9 - Volume (min=0V; max=5V). It seems they use 50K potentiometer but probably anything >10k should work.
At minimum for standalone subwoofer you will need to implement:
- Power On/Off (switch between pins 8,7)
- Volume control 50k potentiometer (probably anything between 10k and 50k will do) between pin 7 and 0 with variable output to pin 9
- Bass control - join two resistors R (I used 7k) and call this join point A. Attach other ends of the resistors to pins 3 and 5 respectively. Attach 50k potentiometer (I used 10k) between point A and ground 0. Attach Variable pin of the potentiometer to pin 4 (Bass input signal). Attach capacitor C between Pin 4 and Ground pin 0 (I used Electrolytic 1uF with negative end to ground) . Resistor R and capacitor C should make simple passive low pass filter (Google for formula) that should short any frequency higher than 80-120Hz to ground and feed frequencies lower than 80-120Hz to pin 4.
PS: I managed to hack 251 control satellite speaker to somewhat work with VS4121 Subwoofer but that is another subject. All electronic parts were salvaged from old broken TV so total cost was $0 but took several days of tinkering for speakers that I could buy used for $10-20 :)
1helpful
Avid101
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
3answers
Broken right speaker
the only way to fix,is to colour code them back together,or go spend some more $$$ on new ones....later
12helpful
2answers
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
5helpful
2answers
How to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Top Altec Lansing Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
