My Hotpoint Aqualtis displayed the F05 message last night. I completely unclogged the pump by removing all hoses and cleaning. I checked water runs through pump fine before re-assembling and then checked water drains now using the pump out cycle. All grand a fixed.. Or so I thought :-( I put the machine on a wash cycle and it fills with water but then at some point it just stops, with a load of water inside, and the screen says 'attention, washing machine cannot fill with water'. I'm stumped because it HAS water in it. A lot of water in fact. Anyone any ideas? :-(
Posted by bathrugby78 on
Ajika coates
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Posted on Feb 11, 2008
douglas smith
  • 1462 Answers
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Posted on Jun 29, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
Anonymous
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
Greg Mills
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
I have a hotpoint aqualtis and i have a fault come up code fo5
F-05 is indeed the water outlet blocked. You need to clean it out, also possibly the pump, & Hoses.
http://www.howtomendit.com/answers.php?id=157950
See above.
http://appliancejunk.com/ge/washer/31-9135.pdf
Service manual above.
Aug 06, 2010 | Hotpoint Washing Machines
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius+ washing machine won't drain and got an F05 error code when trying a wash cycle. Initially the inlet pipes had frozen due to the cold weather but it is now taking in water. However it...
Error code F05 means pressure switch jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum
Remove and clean filter in side hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem
Thankyou.
Jan 13, 2010 | Hotpoint Aquarius WD640 Front Load...
Im getting f -05error towards the end of all programmes and cant get it to spin or pump out on a hotpoint aquarius wmf50
F05 means that the pressure/\water level switch is jammed on full.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove other end of hose onto pump, and check for blockage or obstruction here.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine has f05 flashing on a hotpoint machine it wont pump out and cant get door open
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Wt960p hotpoint
Let me know if you require any firther info.
Pleas rate my solution.
Thanks.
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wd 640
Error code F05 indicates that the water level switch is stuck in the closed position, this is probablly due to a blocked filter or pump.
To gain access to the pump and filter, remove the lower rear panel of washer, locate and remove large black hose fastened to the bottom of tub.
Remove filter inside hose and clean, check inside pump for any blockage or restriction, and make sure the plastic chamber is clean where the small plastic hose is fastened to, as this goes up to the water level switch, and can sometimes get blocked.
Refit filter and hose, making sure it is securely on and fastened, and test, if fault still persists, then you will probably neeed to fit a new water level switch, or preesure switch as it is usually called.
Please rate my solution to your problem.
Thankyou.
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Error f05
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint Washing Machines
Hotpoint wd640 code f05
The filter is located at the rear of the m/c behind the removable panel at bottom of m/c.
Remove lower panel and locate the large black hose at the right side, undo the fixing clip, and remove hose, be careful as there will be some water run out.
You will see the filter inside the hose, remove and clean, check pump is clear, refit hose, make sure you get it on properly,,and test for leaks.
Plz rate my solution.Thanks, and a merry xmas.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
290 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
