Vulcan gas ducted heater not starting
SOURCE: WE HAVE A VULCAN GAS SPACE HEATER AND WE CANT GET
make sure the thermocoupler is in the tip of the pilot flame. Thercouplers fail and when they do they cut all gas off.
SOURCE: Vulcan Oil Heater not operating correctly
If the red light comes on when starting, this means that there is continuity in both exhaust heating and igniting elements and the heater cutout is also working.
The most common problems with this heater is coke & soot build up in the bottom oiltray and clogging the bottom air intake holes, to remove this the heater box has to be dismantled.
SOURCE: where to get vulcan gas heater spare parts?
Google vulcan gas heater spare needed it will find it for you
SOURCE: Hi my vulcan gas wall heater goes 'bang' after a
it sounds like delayed ignition, this is VERY dangerous, you need to verify sequence of operation and fuel air mixture.
SOURCE: Vulcan Ilec central heater main burners turn off after few second
Flame rollout sensors, overheat thermistor, air proving switch, bad earthing, blocked flue. Any of these things can cause your problem. If its a permanent pilot, is it clean burning?? If electronic ignition, is the flame rod clean i.e. no carbon or rust etc.. Safest bet is a qualified gasfitter take a look at it.
