Philips 42" lcd flat screen doesn't turn on. Just a blue light then blinks red 6 times. Model number 42PFL5332D/37
A blue light comes on for a few seconds then turns off, followed by a red light that blinks 6 times. The TV never turns on. This happened while we were watching TV. There was no pop, bang or odor. At first we thought we had to reset the breaker box but the cable box and DVD player still had power. The TV just went dark, except for the blinking red light in six blink intervals.
Posted by Stephen Brush on
4 Related Answers
Anonymous
  • 30 Answers
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
Bad caps in the power supply. Replace all bad cap or replace Power Supply Module. If you choose to try and fix it yourself yourself will need a ESR Meter to check the caps in circuit. Let me know if this helps.
Posted on Oct 16, 2008
Anonymous
  • 1077 Answers
SOURCE: My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 15, 2009
Anonymous
SOURCE: philips hdtv lcd 5 blinking red lights
its a 1080p output failure
Posted on Dec 15, 2009
Anonymous
SOURCE: 42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Posted on Jan 24, 2010
Testimonial: "Thank you for your help, I will give it a shot!"
Tv will not turn on. Makes on going clicking sound only.
http://www.shopjimmy.com/philips-996500042146-power-supply-unit.htm That is the most likely cause of your problem.
Aug 25, 2015 | Philips 42PFL5332D 42 in. LCD Television
Only sound and ambilight no pictures
This problem is most of the time an defect of the inverters.
You can use a repair-kit or replace the circuit boards.
INVERTER BOARD NUMBERS REPAIR KIT NUMBER
Master - 6632L-0470A PNEL-T707A KIT63
Slave - 6632L-0471A PNEL-T708A KIT63
As used on the LG / PHILIPS LCD PANEL TYPE: LC420WU5
Examples of models that use this panel:
• PHILIPS 42PFL7662
• PHILIPS 42PFL9900D10
• PHILIPS 42PFL5332D
• PHILIPS 42PFL7332D37
• PHILIPS42MF337B/37
You can find the parts by Ebay e.g.
Mar 05, 2014 | Philips 42PFL5332D 42 in. LCD Television
My television is a Philips LCD 4 Had it for 2 years.
caps on the PSB-power supply board are blown.... Do you have blinking LED yet?
Best Regards and Semper Fi
Aug 03, 2010 | Philips 42PFL5332D 42 in. LCD Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Error Code Table
0 = No error
3 = Reserved
7 = Total failure
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42 inch LCD HDTV w/HDMI
I CAN'T TURN ON TV
WHEN TRIED TO TURN IT GOES OFF
I SEE RED LIGHT BLINKING ALWAYS.
Dec 11, 2007 | Philips 42PFL5332D 42 in. LCD Television
Problem, please help
The unit should be under warranty. What you're describing is not normal and I would attempt to get a replacement from the place of purchase or take the unit to an authorized repair center. Below is the Philips support page for your unit. You can check warranty status as well as request repair.
Philips 42PFL5332D/37
Dec 07, 2007 | Philips 42PFL5332D 42 in. LCD Television
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
