Question about Vestax Typhoon USB DJ MIDI Controller with Bundled Traktor Software.
Vestax typhoon controller jog wheel stays red
One jog wheel stays red
Posted by David Hooper on
matthew
    New Friend:
Look at the back of your deck there shold be two little nobs that say touch sensor level turn it down to min or at least dont have them all the way up
Posted on Aug 02, 2013
3 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: I just bought the Vestax
Make sure you have loaded the right driver for this and the operating system is allowed. Vista and later sometimes won't work unless you have compatible drivers.
Posted on Jan 05, 2011
Fred Yearian
  • 5603 Answers
SOURCE: i just installed my vestax typhoon and the
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Posted on Feb 12, 2011
virginiarobi
  • 713 Answers
SOURCE: Purchased a Vestax typhoon new, using with a
need to make midi controler your default sound player.
Posted on Feb 17, 2011
How do I get the Vestax vci mk2 to work on a sony vaio notebook? It seems that people have problems with the sony vaio laptop picking up the controller. On the vestax website it says that the problem is...
There probably is a conflict with the camera hardware and or driver. Your best help may be on those Vestax forums. You could try removing the camera drivers in the Sony... but it may be a hardware conflict that may have no solution.
Mar 07, 2011 | Vestax Vci 100 Midi Controller
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Feb 11, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
I just bought the Vestax typhoon but everytime I go to the setup wizard in Traktor it says controller not connected and I'm not able to use the controller
Jan 04, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
Where can i send my vci 100 to get repaired ? neil mk
You don't give your location so start here:http://www.vestax.com/v/ Try contacting the two distributors here:http://www.vestax.com/v/wtbuy/ .
Aug 25, 2010 | Vestax Vci 100 Midi Controller
Vestax vcm 100 driver traktor pro
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
Feb 22, 2010 | Vestax Vci 100 Midi Controller
On the VCI-100, My left jog wheel is slow/sticky. is there any way to adjust it? It also causes the tracks to slow down or go backwards on it's own?
I suspect this uses an optical pickup. You need to open the unit and look at the sensor. If it is an optical pickup, then use the canned air pressure to clean the area of dust.
If it happens to be a mechanical switch, then the mechanical encoder has to be replaced.
Sep 09, 2009 | Vestax Vci 100 Midi Controller
Jog wheel is blocked and hard to spin
Hey, the vci 100 out of the box has the problem of sticky jog wheels, Im not sure how long you have had the interface, but mine took a bit of use to start spinning freely. These jog wheels are definately the weekest link and degrade rapidly, the case is easy to remove there are about 8 screws including one one front and rear edge, you will notice the grafite lubricant used on the jog wheel mechanisim, a fine grade grafite would not go astray when maintaining this moving part
May 06, 2009 | Vestax Vci 100 Midi Controller
Vestax Typhoon USB DJ MIDI Controller with Bundled Traktor Software. Logo
329 people viewed this question
Top Vestax Music Experts
Jeffrey Turcotte
Jeffrey Turcotte
rhodesworks
Lawrence Oravetz
Are you a Vestax Music Expert? Answer questions, earn points and help others
