SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
SOURCE: Lost instructions
here is the owner manual from taylor http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Testimonial: "Thank you, received the manual promptly, appreciate it."
SOURCE: I'm trying to find the
I just pulled my manual, as I recently started a slow carb diet and needed all my measurements. It was fun trying to find it. After finding nothing online (before my search), decided to post mine for everyone out there. It can be found under my photobucket album. Here is the link:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
SOURCE: I need an instruction manual
I posted the manual in my photobucket album here:
Amy
