Philips HD TV MONITOR, VIARUAL, DOLBY, SURROUND.. DATE on back is 2004, DPTV 345 CHASSIS, MODEL #51PW9303/17F, TVRECEIVER LISRED 347H E10839.ITwas getting kinda dual but still working fine ,worked in the mornning but that night I had sound but no pitcher .i took the back off an the three tumbs are lit but dem ,i dont know if they should be this way.the 3 collar lens are a little dusty, i have not clearn them ,the screen inside is clean. CAN YOU HELP ME !!! THANKS LOTS [email protected]
If the picture was somewhat 3d looking before with colors out of line etc--what you have is a convergence problem that has got worse.
Seen a number of sets with this problem--on this model only way to know is locate the two chips, get at them and unsolder all pins on each--if set then comes on (will look bad) you know both chips need to be replaced.
If this is beyond you set is old enough to just replace it--average shop cost for this is over 200 parts and labor.
Let me know if you have questions.
SOURCE: schematic for a 347h e10839 philips tv
You have to replace the DSL Board to fix this problem
SOURCE: OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
SOURCE: Philips 51PW9363-17F - No picture but has sound
Common problem. Goto www.TvRepairKits.com and to get their "No video, audio works " kit.
SOURCE: cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
it wasnt 3d no colors out of line
HELLO I SENT MORE INFO GUESS YOU DIDNT GET IT,IM NEW AT THIS , MY TV HAD NO 3D LOOK TO IT, AN NO COLORS WHERE OUT OF LINE . JUST A LITTLE PAL LOOKING ,SOMEWHAT LIKE THE COLORS WERE FADED ,??? CAN YOU HELP ME ?? THANKS
Thanks so much 4 all your help.should i see any ligth ******* up thew the lens,ther is none , I will clean the lens ,the tubs under the lens are comming on ok, there are 3 of them,one down under each lens. thanks you much ,.have a great day
