Question about Frigidaire Washing Machines
Took back off seems water coming from above, hose are all tight on outside ?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. Check for tips on the link below to identify parts and removal:
Posted on Jun 12, 2012
SOURCE: washing machine
there is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Posted on Dec 20, 2007
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
SOURCE: the water runs right out the machine with the hose on tight.
Hi. I need to bay hose on tight,but i don't know in which store in Brooklyn,NY.Thank You.
Posted on Dec 18, 2008
SOURCE: Roper washing machine leaking water
Might be a cracked water valve or dispenser. To get to it you must remove the skin. Click HERE for info on accessing these fine machines.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 22, 2009
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Apr 27, 2012 | Washing Machines
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Sep 23, 2009 | Roper RAS8445KQ Top Load Washer
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Nov 26, 2008 | Washing Machines
Sep 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Dec 21, 2007 | Washing Machines
Jul 03, 2007 | Maytag Performa PAV2200
47 people viewed this question
