Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
Unit error when connnected a usb flash drive ?
1 Related Answer
Anonymous
SOURCE: My CDA-9886 usb error
I just got an A-male to A-female USB extension cable to hook up to the back of my Alpine CDA-9886 headunit and connect to my 32GB USB. All of the songs are MP3 and works with my brother's headunit. But when the USB is plugged into my headunit, it says error. How can I fix this?
Posted on Jun 07, 2011
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
The hardrive flashes blue but cannot be seen by my PC. I have windows XP
did you try a different, system to plug the drive into?
if the drive works on other systems , then your old xp has issues.
id get off XP , as MS support ends soon.
The XP OS, goes dingdong when you connnect any USB device.
if the USB is bad on PC or the External drive is dead.
so try the drive on one more PC. and now you know which end to work , all this is easy , try another PC.
Oct 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
There is something wrong with my microsft account its not letting me log in and the code is 8015d003
You see the following error message when you try to sign in to Xbox Live:
Sorry, something's wrong with your Microsoft account. Go to https://account.live.com for help.
Status code 8015D003
This may mean that there's a problem with your Xbox profile.
Solutions
To resolve this issue, try the following solutions.
Solution 1: Verify your Microsoft account security information
  1. Go to Microsoft account. If you forgot your password or it doesn't work, reset your password.)
  2. Click Edit security info.
  3. Verify your security information. For example, verify the Phone number, Alternate email address, and Security question information.
  4. Sign out of your Microsoft account, and then sign in again.
  5. Try to sign in to Xbox Live again.
Solution 2: Clear the system cache
  1. Press the Guide button on your controller.
  2. Go to settings and select System Settings.
  3. Select Storage or Memory.
  4. Highlight any storage device, and then press Y on your controller. (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  5. Select Clear System Cache.
    Note Repeat this step three times.
  6. When you are prompted to confirm storage device maintenance, select Yes.
  7. Repeat steps 4-6 three times to fully clear the cache.
Solution 3: Move and then redownload your Xbox Live profile
Note If you want to use a USB flash drive or a USB hard drive to complete these steps, you must format the USB flash drive or USB hard drive for Xbox storage. (See USB flash drive support for Xbox 360.)
  1. Move your profile to a USB flash drive or USB hard drive. To do this, follow these steps:
    1. Plug the USB drive into your console.
    2. From the Dashboard, go to settings and select Storage.
    3. Select All Devices.
    4. Select Profiles, and then select your gamer profile.
    5. Select Move.
    6. Select the Memory Unit that you want to move your profile to.
      Note A Memory Unit can be a USB flash drive, a USB hard drive, or the Xbox 360 Hard Drive. Be sure that you move the profile to a USB flash drive or a USB hard drive.
    7. Remove the Memory Unit from your console.
  2. Redownload your profile. For details, see Download, move, or delete your Xbox Live profile.
Sep 27, 2013 | Thorogood Boots 534-6333 Womens Code 3...
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Dec 25, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Problem with the sandisk 4gb micro sd card. my computer cant format it. Y
some comp cant read the card a cheap fix is go to radio shack and get a reader/writer card its a usb connnection and should work for it did for me even my printer couldn t read my 4 gb
Aug 10, 2009 | SanDisk 4GB microSD High Capacity Memory...
Transcend 2GB Jet Flash V30 problem
There are some specification of USB speed. There are usb 1.0 , 1.1 , 2.0 . 2.0 is fastest among these. Normally back panel USB ports are USE 2.0 s. If you have installed your motherboard successfully , they should be working fine. Please try Installing those. If it not works, probalby your motherboard has not hte capablity of running usb 2.0 s.
thanks
Apr 18, 2009 | Computers & Internet
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
