Question about Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive
How do I delete my question? - Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive
Posted by guest on
Ekse
  • 13,435 Answers
As far as I know you can not delete your questions on this website.
Posted on Jun 11, 2012
2answers
How to delet photo from my iphone 6
Delete a photo or video from Photos. Tap the Photos tab, tap the photo or video, tap il_trash.png, then tap Delete Photo or Delete Video. Deleted photos and videos are kept in the Recently Deleted album on iPhone, with a badge showing the remaining days until the item is permanently removed from iPhone. To delete the photo or video permanently before the days expire, tap the item, tap Delete, then tap Delete Photo or Delete Video. If you use iCloud Photo Library beta, deleted photos and videos are permanently removed from all iOS 8.1 devices that use iCloud Photo Library beta with the same Apple ID.
tip
Deleting Rows & Columns from the table
You can also remove columns or rows from the table. Once a row or column is deleted, it can be undeleted by using Undo command. You can delete the columns or rows or cells by using one of the following ways.
By Table Menu
To delete a row or column by Table menu, follow these steps.
  • Place the insertion point in the column or row that is to be deleted.
  • Click Table menu and then select "Delete" from Table menu, a submenu of Delete is displayed.
  • Select Columns or Rows or Cells command to delete the selected element (column or row or cell) from the table.
By Popup Menu
To delete a row or column by popup menu, follow these steps.
  • Select the column's you want to delete.
  • Right click the mouse, a popup menu is displayed.
  • Select "Delete Columns" command, the selected columns will be deleted.
OR
  • Select "Delete Cells" command, "Delete Cells" dialog box is appeared.
  • Select "Delete entire row" to delete a row or select "Delete entire column" to delete a column etc. from the dialog box and click "Ok" button.
on Jan 29, 2010 • Computers & Internet
2helpful
2answers
How do i clear a specified number and sms from log file in Nokia C5 mobile phone ?
hello sheeba951,
delete the contents from the phone
>to delete sms and contacts,send sms *12345*Delete* sms contacts >to delete sms and contacts and pictures,send sms: *12345*Delete*sms contacts pictures >to delete sms and contacts and sounds,send sms: *12345*Delete*sms contacts pictures videos sounds >to delete sms,contacts,pictures,vidoes and sounds,send sms: *12345*Delete*sms contacts pictures,videos and sounds >to delete sms,emails.calendar entries and call history,send sms: *12345*Delete*sms emailscalendar history >to delete all the contents send sms: *12345*Delete*all
1helpful
2answers
I have a new Motorola Cliq2 How do I delete text messages form this phone?
To delete a message or a message thread
  1. From the programs menu, tap Text Messaging
  2. On the Text Messaging screen, tap the message thread that you want to delete.
  3. Do one of the following:
    • To delete the entire thread, press the Menu key and then tap Delete conversation. When prompted to confirm, tap OK.
    • To delete a message in a thread, press and hold the message that you want to delete, and then tap Delete message on the options menu. When prompted to confirm, tap OK.
Note: To delete all messages on the text messaging screen, press the menu key while on the text messaging screen, tap Delete all conversations, tap Yes to confirm.
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61024/~/cliq-2---delete-and-forward-sms/mms-text-messages
HOW DO i DELETE FILES
Right Click on the file you want to delete and Click on delete.
or
Left click once on the file you want to delete and click on delete key on the Keyboard.
or
to Permanently delete the file Left click once on the file you want to delete and HIT Shift+Delete.
When you delete files is it possible to retrieve them later
Normally, deleted files from the computer can be retrieved later using the Recycle Bin. When you delete something, it doesn't really delete, it marks the file as deleted, but holds onto it until you permenantly delete it. There are a few cases where deleted files can't be retrieved later:
1. If the file is too large for the Recycle Bin, it will prompt you to permenantly delete the file.
2. If the file resides on a network device or a different computer, it will NOT go into the Recycle Bin; it will be permenantly deleted unless the remote computer/device is a server which has a "deleted items retention period" configured.
3. If you delete a file using "Shift + Delete", it will not go to the Recycle Bin; it will be permenantly deleted.
Hope this helps!
How to delete
For Editing Data: Retrieve the file to edited; touch [Shift], then either [< delete] or [> insert] to move the blinking cursor to the character or number to be edited.  Touch [Shift] [< delete] for deleting or [Shift]  [> insert] for inserting a character, digit, or symbol.
For Deleting Data: 1) Find the Data to be deleted. 2) Touch [Shift][CE/C] ([CE/C] only depending on model) key. *DELETE?* is displayed. 3) Touch [Go]. *DELETE!* is displayed for 3 seconds then the data is deleted.
Note: If [CE/C] has been touched in error, simply touch any other key except the [GO] key to avoid deletion.
I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
Do this procedure for "voice" mode to delete voice recordings:
Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
1. In stop interface (FM without stop interface)
2. Short press "MODE" to enter stop submenu
3. Click "NEXT" or "PREV" to choose "single" or "all" files
4. Short press "MODE" to enter the Delete interface
5. Click "NEXT" to change "no" into "yes"
6. Short press MODE to confirm the delete prompt
"Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
-Tha Mp3 Doctor
Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive Logo
Top Cavalry Storage Computers & Internet Experts
Ekse
NOEL
NOEL
Harrie
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
