Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive Logo
Question about Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive
Are you serious? - Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive
Posted by guest on
  • Anonymous Jun 11, 2012
    can you mention your question correctly please ?
Anonymous
  • 118 Answers
Tell me your problem please
Posted on Jun 11, 2012
The service light blinks and says esp runs rough
Light blinking means you have a misfire that's serious enough to cause substantial damage to your catalytic converter
http://ricksfreeautorepairadvice.com/flashing-check-engine-light-is-serious/
Flashing check engine light is serious Ricks Free Auto Repair Advice
Electronic stability control & abs & brake assist warning indicator lights are coming on after an accident. How serious are they?
You have damage to the front area brake system. It could be very serious but if car stops OK most likely not that serious you just won't have abs or traction control. The damage is most likely a speed sensor or something similar. I said it could be serious that is only worst case.
Here is a breakdown of what lights mean
ABS keeps your breaks from locking up
BREAK ASSIST helps your breaks
Traction control if you one wheels spin more than others system adjust wheel spiN
3helpful
Need engine diagram serious 2 engine 3800
I did not find a single page for an engine diagram but this link should provide a serious of images of engine diagrams for a 1997 LaSabre
1helpful
I bought serious magic visual communicator pro 2 on amazon.com but the product key is not working. I called adobe and they said that I should ask for a refund. I am not sure that the seller will give me a...
Issue Activation fails when you attempt to install and launch a legacy Serious Magic product.
Reason Adobe has chosen not to renew the hosting account for the Serious Magic web site. The hosting contract expired on Nov. 3, 2008. Activation for Serious Magic products that rely on this server is no longer supported by Adobe. SolutionDo one of the following:
1. Upgrade to the latest Adobe-branded version of the product.Note: DV Rack is now Adobe OnLocation. The most recent version of Adobe Ultra was Ultra CS3. Ultra was not included in CS4, however, color keying is available in After Effects CS4. A tutorial on basic color keying is available here.
2. Download and run the Serious Magic legacy product activation tool.Instructions for SMActivate.exe:
  1. Extract the .zip file to a convenient location.
  2. Double-click SMActivate.exe. The application will display a list of Serious Magic products to be activated.
  3. Click OK.
Your product is now activated and ready to use. If no qualifying products are detected, it will display the message: "No legacy Serious Magic applications detected."
This change affects the following Serious Magic products:
  • Ultra NTSC VxxV
  • Ultra PAL XxxX
  • Ultra 2 PAL BPWB
  • Ultra 2 NTSC BNWB
  • Visual Communicator 1 Studio SxxS or TxxT
  • Visual Communicator 2.0 CxBC
  • Visual Communicator 2.0 Web CxWC
  • Visual Communicator 2.0 Pro CxPC or CxQC
  • Visual Communicator 2.0 Studio CxSC or CxTC
  • DV Rack DxxD
DV Rack Express requires a special version of the activation tool, available here. This affects the following Serious Magic product:
  • DV Rack Express FxxF
For DV Rack Express, do the following:
  3. Select the checkbox for DV Rack Express.
  4. Click Activate. This will create a file, smact21.db, in the C: root.
  5. Move that file to c:\program files\serious magic\dv rack express\bin
The following Serious Magic products do not use activation, or use alternative activation and are not affected:
  • DV Rack 2.0*
  • Ovation
  • VlogIt!
* DV Rack 2.0 uses activation through a third party company named Softwrap, which resides on a server that is not affected. http://www.softwrap.com/
Note: Ultra CS3 is an Adobe product and is not affected.
Engine light is on. is this serious?
It means something isn'nt at peak.
Not immediately serious just make sure your water and oil are proper, The dealer would be your best bet for diagnostics. and resetting the light. Good luck
Top Cavalry Storage Computers & Internet Experts
Marvin
Marvin
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
