Screen is all white
SOURCE: I have an action replay ds media version - for
my sons action replay por the dsi worked for 2 weeks and then stopped. it doesnt even appear on the touch screen when you have it in the slot. tried resetting it following the instruction manual and add the codes again but it says there is not enough free space to load the codes. any ideas what else to do
SOURCE: nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
SOURCE: red ds lite screen
When the screen has a red hue there are two possibilities:
The screen is broken or the connector has moved.
The "water" is in fact the liquid crystal diplay that is broken.
Replacing the screen will cost about € 20
Here you can find the instructions:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Please rate!
SOURCE: Nintendo DS Top Screen turns on but is just white.
Ok I found the wire. Click Here to buy it.
SOURCE: top screen is non readable nintendo ds
Hi you have done one of two things to your ds.
1) you have somehow unstuck the top plastic protection screen that covers the lcd screen and re-stuck it but have got fingerprints etc on it, hence the blur.
2) The more obvious thing is you dropped the de or gave it a bang and the ribbon feeding from the top screen to the lower screen through the left hand hinge is damaged or it has become slightly unclipped where it meets the motherboard.
Either way you will need to take the DS apart to solve. It can be tricky so if you are not confident bring it to a repair shop, it is an easy fix and wont cost the earth to fix.
If it is still under warranty send it back to Nintendo to fix.
