Hi this will take you to the page for your board... http://support.asus.com/Download.aspx?SLanguage=en&m=P4S333-VM&p=1&s=15 hope this helps you!
SOURCE: DDR
Hey, checked up on the motherboard and it does work with pc3200 or 400mhz...
All the best
John
SOURCE: ASUS P4S333-M MOTHERBOARD SOUND DRIVER DOWNLOAD WANTED
visit the link below for your proble..
http://www.nodevice.com/driver/P4S333-M/get18362.html
good luck
SOURCE: Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
SOURCE: ASUS CUSI-M ACPI BIOS Revision 1007
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
