Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on Jun 11, 2012
Siemens coffee maker model tk540001 brewing unit is stuck!
I have siemens suppressor compact coffee maker tk54001 model. The brewing unit is unlocked according to the handle control but the cartridge is still stuck tight and won't come out. There is no service centre where I live but I called the Auckland office and they said that the internal travel lock sounded like it was on and would need to be reset. I have the screwdriver to get into the machine but need some instructions how to go about this. Can anyone help?
Martin Dion-Liu
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 20, 2013
Martin Dion-Liu
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4248
Points
Hi, I am a user with the same problem but on a Siemens TK580001. Is the solution applicable 1:1 as the two models have different panels?
2 Related Answers
Anonymous
  • 1216 Answers
  • Posted on Oct 30, 2010
SOURCE: I own a Meile CVA 4070 coffee system. The Brew
use any method which helps you
Press & hold down Hot Water button & small coffee buttons & turn ON WITH LIGHT. Release buttons.
Press & hold Large coffee button and hold until you see two '1's on the left side of the screen. Release.
Press & hold medium coffee button until you see two '2's.
Release.
Hit & release quickly Large coffee button.
Brew unit should be reset.
or
Turn your machine off. Close the door. Depress , holding it down, press then let go of both. Then press 3 times. On 3rd time, hold it until Service menu appears. Select then press left arrow to turn from to . Then press right arrow by This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu.
Regards.....
Anonymous
  • 1833 Answers
  • Posted on May 04, 2011
SOURCE: I have a two year Problem
Hi, First turn off and unplug your coffee maker. Unscrew the two screw holding the outlet and remove it. you can follow the service manual for help.
Magnifica s ground coffee goes to ground container without extraction
I had the same problem with my Siemens EQ.300. The problem was residues that are sticked to brewing unit. Here is the solution for my Siemens EQ.300
Take a plastic brush and clean all part of the brewing unit, deeply, under tap water for 5 minutes. Dry gently, and re-inserted to the Siemens EQ.300 machine.
Update: After a while, same problem happened again. This time, I have washed my coffee machine's brewing unit in the dishwasher. Result is perfect!
https://www.izreview.com/siemens-eq-3-espresso-coffee-machine-review/#Siemens_EQ300_dispensing_coffee_into_the_drip_tray3_24_2022_2_02_38_pm.jpg
What is error 5 on Siemens suppressor S40 coffee machine
Turn off the machine, remove the power plug for 10 minutes and plug it back in. If this doesn't work, call Siemens. Their service is great.
1helpful
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Platinum B70 "brew temp set"
Brian, sorry, (re post ) with complete question? and make and model
Where can I find a service manual for my Siemens TK54001/02
Choose the following link and register your product .You can get the support of your oven from the nearest service center close to the place.
log on to : http://www.siemens-home.com/
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
2helpful
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
2helpful
Siemens Espresso machine TK54001 water leaking inside into the tray
Check for a bad o-ring behind the removeable brew group where it attaches to the boiler. I have seen them go bad in as short as 1/2 year.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
