The phone is new and 3 months used carefully ..the blue line has been from one week after charging during the night
SOURCE: Can't charge the battery anymore (device was not used during couple of months)
pls first confirm the charger is working or not and then kindly leave the pda for like 2 hours on charge it will start charging , when u store these devices for longer period kindly fully charge the battery and then store , when battery drains during non use it drops to a certain level from where it might come back or might not , pls leave the battery on charge for like 2 or 3 hours first and then u will see charging signs or light
pls rate me well !
SOURCE: Dropped my iphone 3G, screen went black with some
It just happened to my this afternoon. My iphone dropped out of my pants pocket to the ground. The front lcd of the iphone hit the ground and it when blank/black. My iphone happened just like what you've described. I got my fixed. I opened it up and found the connector of the lcd was loose. I securely reconnected it and voila!!!! It works again like a charm! Goodluck to you all who has the same problem.
SOURCE: my iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
SOURCE: phone won't turn on at all battery was fully charged when it died
just had the same problem! hold the top sleep button and the middle button for at least 10 seconds until the apple logo comes up then try start it
Testimonial: "I had tried that but I guess not long enogh so thanks for the info. Very Happy to get all my info back!"
SOURCE: iPhone won't charge - stuck in screen with battery and bolt
i have the same problem with my iphone 3gs 32gb have you found something that has worked? ive tried everything let me know if u find a way!! please!
