SOURCE: screen shows use new ac adapter or reinsert
i found a solution to my problem. i just let the cam on until the battery is totally empty and recharge it.
tell me if it worked for you
SOURCE: sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
SOURCE: camcorder won't charge up
Its problem of DC-IN jack where you hook ac charger. This jack needs to be replaced.
Let me know exact model of camcorder to provide you part number of DC-In jack.
SOURCE: Sony DCR-VX2100 will Not Power on By Battery Unitl I connect AC
this problem is by the DD board of the camcorder their is a power ic in the DD board,which provides the supply to the camcorder.
