My Brother PE770 is stuck programmed on the small hoop and won't change its programming to the medium or large hoop regardless if I press the buttons to program it to the other hoop sizes or if I actually put those hoops on the machine.
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
SOURCE: I bought a large hoop for my machine. But I still
From what I have been able to find out about this model, the embroidery area is limited to 4 x 4.
A larger hoop cannot change the built-in configuration of the machine's computer.
You can use a larger hoop, stitch out what you can and then re-hoop to finish - this is not easy to do.
Measuring the distance between the letters and then centering the last letter to match the previous stitching can be done, but it takes a little practice.
You can make a template using tear away stabilizer.
Stitch out the first 5 letters. Carefully remove the stabilizer - this is going to be a portion of the template.
Hoop another sheet of tear-away and stitch out the last 5 letters (these will partially overlap the first 5 when finished). Remove as in the first step.
Overlap the two templates (tape them together) and this should help you align the letters when you have to re-hoop.
Testing and a bit of practice is how I do it.
There is editing software for splitting designs and if you are interested - check Embird as it seems to be the most reasonable.
