Question about Olympus Stylus Cameras
I want to turn off the flash, and don't know how to do that.
Press cursor-right (marked with a lightning bolt) to bring up the flash options. Select the lighting bolt in a circle with a slash through it to turn off the flash.
Posted on Jun 11, 2012
SOURCE: Battery charger won't charge
I'm sorry to say I don't know much about Olympus digital cameras, I've never had one on the bench.
I would take your camera and charger to a shop that sells Olympus batteries try a different battery first, this way you can try it out before you buy and make sure the camera and charger are working ok...
The battery is a Li-Ion, when these get flattened too far they shut down and will refuse to charge, they can sometimes be recovered by using a power supply to lift them but you must be very careful (use a 300ma wall wart at just over the rated voltage of the battery for 10 mins then put it back in the charger) as they can catch fire if over charged, shorted or connected backwards also if its been so flat it refuses to charge its certainly past its best and should be replaced as its likely it will let you down again.
On the other hand it could be the charger, so best to try and check out both before buying anything.
If it happened very suddenly and the battery was still able to run the camera for quite a while I would think a charger problem is more likely, if the battery has been taking less time to charge recently and lasting shorter times its more likely the battery..
Having said that the protection circuits can shut down a seemingly good battery for other reasons.
If you find its the charger third party (non Olimpus) chargers are available quite cheaply on ebay as are batteries
Best of luck
Posted on Jun 14, 2008
SOURCE: Olympus Stylus 710- no flash mode
My flash still won't allow me to turn it on
Posted on Nov 02, 2008
SOURCE: grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Posted on Sep 10, 2009
SOURCE: Olympus E-300 Digital SLR storing black images.
Most likely the shutter "curtain" (a few pieces looking like sheet metal just behind the mirror, designed to protect the camera CCD from dust and damage due to too much light) is not opening. This will require servicing by Olympus, since you will have to take the camera apart to be able to reach this camera part. Unfortunately, this may be a pretty expensive repair.
Posted on Dec 09, 2009
SOURCE: Olympus Stylus 300 need date/time stamp to print
On Page 113 of the user manual (see the link below) shows you how to set the menu up to print the date onto the print when printed
Top Menu >Play >Print <up down arrows>Then select No, Date or Time
the user manual is available from here
http://www.olympusamerica.com/cpg_section/cpg_download_manuals.asp
choose your camera from the dropdowns
Direct link to the user manual
http://www.olympusamerica.com/files/oima_cckb/Stylus_300_400_Digital_Mju_300_400_Digital_Reference_Manual_EN.pdf
Posted on Mar 31, 2010
Feb 22, 2012 | Olympus Stylus 850SW Digital Camera
Jul 21, 2011 | Olympus Stylus Tough6000 Protective Clear...
May 25, 2011 | Olympus SP-350 Digital Camera
May 03, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
May 26, 2009 | Olympus Camedia Stylus 300 Digital Camera
Mar 13, 2009 | Olympus Camedia Stylus 300 Digital Camera
Feb 18, 2009 | Olympus Camedia Stylus 300 Digital Camera
Nov 25, 2007 | Olympus Stylus 710 Digital Camera
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
May 02, 2019 | Olympus Cameras
135 people viewed this question
