I cant seem to hook up the cars hot wire to the players power wire or the cars ground to the players ground. I have a SCOSCHE FGA Floating Ground Adapter that hooks in to my Kenwood with 14 teen different color wires,9 of which goes into the input end of the adaper and 5 which comes out tthe other end, which is lable output.5 wires are left which comes directly from the kenwoods plugin harness are left. Can i be Helped?
The installation instructions including wiring diagrams begin on page 20 of the manual.
SOURCE: KDC 128 CD Player
It could be that the player is going into protect mode. This is normally due to a short in a speaker cable, or one or more of your speakers is blown. Try disconnecting all of your speaker cables at the speaker end and make sure the connectors don't touch. Power it up again and see if it stays on. Bear in mind you won't hear anything. If it powers up. Carefully plug each speaker back in. It will power off if you plug in the dud! If it still doesn't power up. disconnect all of your speaker cables at the player end. If it powers up this time one of your cables is shorted. Same as the speakers, plug one pair of wires in at a time to find the dud. If it's still switching off. It could be a blown circuit on the output stage of the amp. Here's a silly question. Does the player get hot? All this assumes that you have had this player working with these cables and speakers before. If not check that the speakers are the correct rating (Resistance in Ohms) for the player. And lastly here's where you can get a manual http://www.kenwoodusa.com/Support/Car_Files/#_
SOURCE: Kenwood stereo Won't turn on
look and see if there is a reset... usually a tiny hole you can push a pen point into...(lightly)
SOURCE: Kenwood car radio/cd player Model No KDC-3027
Do you like need the colors codes for the harness like speakers and and all?
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
SOURCE: need color codes for a kenwood kdc- 122p head unit in dash.
Generally you can find these manuals freely available at the manufacturers website, however it usually take ages worth of searching and i thought id save you the hassle,
Head to this link for your units entire manual.. Page 17 i think it is exactly.
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf
There a good little unit but sold a few when i was working in the industry.
Otherwise generally you can pick up pre wired pugs that adapt the cars harness via one plug to the back of the stereo avoiding any splicing. If youre interested in them head to this website,
http://www.aerpro.com.au/contents.php?menu=Harnesses
Hope this helps,
Have a happy easter
Cheers
Steve
