UNIDEN is notorius for this. It could be losing connection to the base - are you moving around while on the phone? or it could be the battery is not holding a sufficient charge. You can move the base unit to see if that helps - maybe something is interfering with the signal. You can try taking the battery out of the phone and putting it back in. If that doesn't work then try swapping the phones and putting them in each others charger. If that doesn't work then try letting the battery die by leaving the phone off the charger for 24 hours and then recharging for 24 hours. Good Luck!
SOURCE: Problem with Uniden D1680 Cordless Phone I have a
Press MENU/SELECT to bring up the menu. Select "Ans. Setup". Select "Ring Time".
The above is condensed from this manual.
