Tv , i cant change green tent.
SOURCE: Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
SOURCE: samsung hc-p4741w flashing red light
That sound is made by the power supply who's gooing in protection mode due to some overcurent in secondary. Could be many reasons: conv. amp. IC's, video amp.IC's etc. In my opinion more then 70% chances to be the STK for convergence. Need to be troubleshooted by a tech.
SOURCE: samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
SOURCE: Samsung HC-P4752W 47 turns its self on and off.
it might be set on sleep mode check again
shaun
SOURCE: Greenish haze on my Samsung HC P4741W
If you purchased it new then this clearly should not happen - if it is second hand and therefore older then the red tube could be burnt out. The convergance may simply require allignment if the set has been knocked about trying to get it to its final resting place - this would need a tech on site to set it up.
